Gradient With Respect to a Set of Coordinates
In summary, we have shown that the gradient of a scalar function ##U## with respect to the difference in positions between two particles is equal to the negative of the gradient of ##U## with respect to the first particle's position. This can be extended to multiple dimensions by using vector notation.
cwill53
220
40
TL;DR Summary
Prove that ##\nabla_1U(\mathbf{r}_1- \mathbf{r}_2 )=-\nabla_2U(\mathbf{r}_1- \mathbf{r}_2 )##
In physics there is a notation ##\nabla_i U## to refer to the gradient of the scalar function ##U## with respect to the coordinates of the ##i##-th particle, or whatever the case may be.
A question asks me to prove that
$$\nabla_1U(\mathbf{r}_1- \mathbf{r}_2 )=-\nabla_2U(\mathbf{r}_1- \mathbf{r}_2 )$$
How do you actually extend this idea to ##\mathbb{R}^n## though? I'm not sure if everything I have written below makes sense or is correct, I'm hoping to get some clarification. The weakness is in my mathematics.
Suppose I have ##X## be an open set in ##(\mathbb{R}^n )^m## and ##f:X\rightarrow \mathbb{R}## a scalar valued function; and let ##A=\left \{ \mathbf{r}_1, \mathbf{r}_2, ..., \mathbf{r}_m \right \}\subseteq X##.
Then
$$\nabla f= \begin{bmatrix}
\frac{\partial f}{\partial x _{1_{1}}}& \frac{\partial f}{\partial x _{2_{1}}} &\cdots & \frac{\partial f}{\partial x _{n_{m}}}
\end{bmatrix}^T \in (\mathbb{R}^n )^m $$
$$\nabla_k f= \begin{bmatrix}
\frac{\partial f}{\partial x _{1_{k}}}& \frac{\partial f}{\partial x _{2_{k}}} &\cdots & \frac{\partial f}{\partial x _{n_{k}}}
\end{bmatrix}^T \in \mathbb{R}^n $$
where the subscript ##k## denotes that the derivatives are taken with respect to the $n$ coordinates of the ##k##-th element of the indexed set ##A=\left \{ \mathbf{r}_1, \mathbf{r}_2, ..., \mathbf{r}_m \right \}\subseteq X##. Let ##\mathbf{r}_i, \mathbf{r}_j \in A##, and let
\mathbf{r}_i= \begin{bmatrix}
x_{1_{i}} & x_{2_{i}} & \cdots & x_{n_{i}}
\end{bmatrix}$$
$$\mathbf{r}_j= \begin{bmatrix}
x_{1_{j}} & x_{2_{j}} & \cdots & x_{n_{j}}
\end{bmatrix}
and let ##\mathbf{x}= \mathbf{r}_i- \mathbf{r}_j##.
My questions are:
1. **Is it true that ##\nabla_k f \in \mathbb{R}^n## ?**
2. **Given the above, how should ##\nabla _i f(\mathbf{x})## be written? Can someone give explicit steps for the chain rule manipulations that need to occur?**
cwill53 said:
TL;DR Summary: Prove that ##\nabla_1U(\mathbf{r}_1- \mathbf{r}_2 )=-\nabla_2U(\mathbf{r}_1- \mathbf{r}_2 )##
In a simple one-dimension case of harmonic oscillator
[tex]U(x_1 - x_2) =\frac{k}{2} ( x_1 - x_2)^2 [/tex]
[tex]\frac{\partial U}{\partial x_1}=k(x_1-x_2)=-\frac{\partial U}{\partial x_2}[/tex]
Forces from the spring are same but have opposite signs at the ends.
Do you want to extend it from 1D to 3D or more higher dimensions, or from 2 to more ends or particles, or both ?
Likes topsquark
I'm not sure I follow what you are doing there. If we have two particles in 3D, then we can represent the position of each particle as:$$\mathbf{r_1} = (x_1, y_1, z_1), \ \mathbf{r_2} = (x_2, y_2, z_2)$$Technically, the potential is a function of six coordinates:$$V:\mathbb R^6 \rightarrow \mathbb R$$Where the first three coordinates represent the position of first particle and the second three coordinates represent the second particle.
Assuming, however, that the potential is a function of the difference in position between the particles, then we have a "reduced" potential function:$$U: \mathbb R^3 \rightarrow \mathbb R$$Where the argument here is the difference in position of the two particles.
I've used two different letters here to emphasise the different functions involved. Technically, we have:
$$V(\mathbf{r_1}, \mathbf{r_2}) \equiv V(x_1, y_1, z_1, x_2, y_2, z_2) = U(\mathbf{r_1} - \mathbf{r_2}) \equiv U(x_1 - x_2, y_1 - y_2, z_1 - z_2)$$Now, we have two gradient functions defined here:
$$\mathbf{\nabla_1}V = (\frac{\partial V}{\partial x_1}, \frac{\partial V}{\partial y_1}, \frac{\partial V}{\partial z_1})$$$$\mathbf{\nabla_2}V = (\frac{\partial V}{\partial x_2}, \frac{\partial V}{\partial y_2}, \frac{\partial V}{\partial z_2})$$And, now we can see what is meant by these two gradients acting on the potential function ##U(\mathbf{r_1} - \mathbf{r_2})##:
$$\frac{\partial V(x_1, y_1, z_1,x_2, y_2, z_2)}{\partial x_1} = \frac{\partial U(x_1-x_2, y_1-y_2, z_1 - z_2)}{\partial x_1} = \frac{\partial U(x_1 - x_2, y_1 - y_2, z_1-z_2)}{\partial x}$$Where ##\frac{\partial U}{\partial x}## is just the usual partial derivative of ##U## with respect to its first argument (which we've called ##x##). And, of course, we have the equivalent for ##y_1## and ##z_1##.
And, to take the partial derivate wrt the second coordinates, we need to use the chain rule:
$$\frac{\partial V(x_1, y_1, z_1,x_2, y_2, z_2)}{\partial x_2} = \frac{\partial U(x_1-x_2, y_1-y_2, z_1 - z_2)}{\partial x_2} = -\frac{\partial U(x_1 - x_2, y_1 - y_2, z_1-z_2)}{\partial x}$$This leads us to the conclusion that:
$$\mathbf{\nabla_1}V = -\mathbf{\nabla_2}V$$In the special case where the potential can be written as a function ##U## of the difference in positions.
Finally, we can adopt the notation:$$\mathbf{\nabla_1}U(\mathbf{r_1} - \mathbf{r_2}) \equiv \mathbf{\nabla_1}V(\mathbf{r_1}, \mathbf{r_2})$$$$\mathbf{\nabla_2}U(\mathbf{r_1} - \mathbf{r_2}) \equiv \mathbf{\nabla_2}V(\mathbf{r_1}, \mathbf{r_2})$$To get the required result.
Note that a physicist would assume implicitly almost all of this supporting mathematical complexity. But, if you want to justify this fully, then this is what I've shown.
Finally, if you want to extend this to more dimensions, then the same steps apply at every stage, but the vector notation would get more complicated. Instead of ##x_1, y_1, z_1##, we would need something like ##\mathbf{r_1} = (x_{11}, x_{12} \dots x_{1n})## and ##\mathbf{r_2} = (x_{21}, x_{22} \dots x_{2n})## for the ##n## coordinates of the two particles.
PS the simpler approach is just to assume/state that:
$$\frac{\partial U}{\partial x_1} = -\frac{\partial U}{\partial x_2}$$and hence$$\mathbf{\nabla_1}U = -\mathbf{\nabla_2}U$$Where ##U(\mathbf{r_1} - \mathbf{r_2})## is the potential function. Whether that constitutes a "proof" is a moot point.
FAQ: Gradient With Respect to a Set of Coordinates
What is a gradient with respect to a set of coordinates?
The gradient with respect to a set of coordinates is a vector that represents the rate and direction of change of a scalar field in a multi-dimensional space. It indicates how much the scalar quantity changes as one moves in the direction of each coordinate axis.
How is the gradient mathematically defined?
Mathematically, the gradient of a scalar function \( f(x_1, x_2, \ldots, x_n) \) with respect to a set of coordinates \( (x_1, x_2, \ldots, x_n) \) is defined as the vector of partial derivatives: \( \nabla f = \left( \frac{\partial f}{\partial x_1}, \frac{\partial f}{\partial x_2}, \ldots, \frac{\partial f}{\partial x_n} \right) \).
What does the gradient tell us about the function?
The gradient provides information about the steepness and direction of the steepest ascent of the function. The magnitude of the gradient indicates how quickly the function value increases, while the direction of the gradient points towards the direction of the most rapid increase.
How do you compute the gradient for a function of multiple variables?
To compute the gradient for a function of multiple variables, you take the partial derivative of the function with respect to each variable independently. For a function \( f(x, y, z) \), the gradient would be computed as \( \nabla f = \left( \frac{\partial f}{\partial x}, \frac{\partial f}{\partial y}, \frac{\partial f}{\partial z} \right) \).
What are some applications of gradients in science and engineering?
Gradients are widely used in various fields such as physics, engineering, and machine learning. They are essential in optimization problems, where gradients guide the search for minimum or maximum values. In physics, gradients describe how physical quantities like temperature, pressure, or electric potential change in space, while in machine learning, they are crucial for training models through techniques like gradient descent.
