MHB Gram-Schmidt Orthonormalization .... Garling Theorem 11.4.1 ....
  • Thread starter Thread starter Math Amateur
    Theorem
The discussion centers on the proof of Theorem 11.4.1 from Garling's book, specifically regarding the Gram-Schmidt orthonormalization process. The key focus is on demonstrating how the expression for \( f_j \) leads to the conclusion that the span of the orthonormal vectors \( e_1, \ldots, e_j \) equals the span of the vectors \( x_1, \ldots, x_j \) and the subspace \( W_j \). The proof involves showing that \( e_j \) is constructed from \( f_j \), which is orthogonal to the previous vectors, thus ensuring linear independence. Additionally, the orthonormality of the vectors \( e_1, \ldots, e_j \) is confirmed by calculating their inner products, establishing that they are indeed orthonormal. This rigorous approach clarifies the relationship between the spans and confirms the validity of the theorem.
Math Amateur
MHB
I am reading D. J. H. Garling's book: "A Course in Mathematical Analysis: Volume II: Metric and Topological Spaces, Functions of a Vector Variable" ... ...
I am focused on Chapter 11: Metric Spaces and Normed Spaces ... ...
I need some help with an aspect of the proof of Theorem 11.4.1 ...
Garling's statement and proof of Theorem 11.4.1 reads as follows:
View attachment 7921In the above proof by Garling we read the following:
" ... ... Let $$f_j = x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i$$. Since$$ x_j \notin W_{ j-1 }, f_j \neq 0$$.
Let $$e_j = \frac{ f_j }{ \| f_j \| } $$. Then $$\| e_j \| = 1$$ and
$$\text{ span } ( e_1, \ ... \ ... \ e_j ) = \text{ span } ( W_{ j - 1 } , e_j ) = \text{ span }( W_{ j - 1 } , x_j ) = W_j $$
Can someone please demonstrate rigorously how/why $$f_j = x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i $$
and
$$e_j = \frac{ f_j }{ \| f_j \| }$$imply that $$\text{ span } ( e_1, \ ... \ ... \ e_j ) = \text{ span } ( W_{ j - 1 } , e_j ) = \text{ span }( W_{ j - 1 } , x_j ) = W_j$$
Help will be much appreciated ...
Peter
and
Peter
Reflecting on my post above I have formulated the following proof of Garling's statement ... ...$$\text{ span } ( e_1, \ ... \ ... \ e_j ) = \text{ span } ( W_{ j - 1 } , e_j ) = \text{ span }( W_{ j - 1 } , x_j ) = W_j$$
We have $$e_1 = \frac{ f_1 }{ \| f_1 \| }$$ and we suppose that we have constructed $$e_1, \ ... \ ... \ e_{j - 1 } $$, satisfying the conclusions of the theorem ...Let $$f_j = x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i$$Then $$e_j = \frac{ f_j }{ \| f_j \| } = \frac{ x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i }{ \| x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i \| }$$
So ...
$$e_j = \frac{ x_j - \langle x_j , e_1 \rangle e_1 - \langle x_j , e_2 \rangle e_2 - \ ... \ ... \ ... \ - \langle x_j , e_{ j - 1 } \rangle e_{ j - 1 } }{ \| x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i \| }$$ Therefore ...
$$x_j = \| x_j - \sum_{ i = 1 }^{ j-1 } \langle x_j , e_i \rangle e_i \| e_j + \langle x_j , e_1 \rangle e_1 + \langle x_j , e_2 \rangle e_2 + \ ... \ ... \ ... \ + \langle x_j , e_{ j - 1 } \rangle e_{ j - 1 }$$Therefore $$x_j \in \text{ span } ( e_1, e_2, \ ... \ ... \ , e_j )$$ ... ... ... ... ... (1)But $$W_{j-1} = \text{ span } ( x_1, x_2, \ ... \ ... \ , x_{ j - 1 } ) = \text{ span } ( e_1, e_2, \ ... \ ... \ , e_{ j - 1} ) $$ ... ... ... ... ... (2) Now $$(1) (2) \Longrightarrow \text{ span } ( x_1, x_2, \ ... \ ... \ , x_j ) \subseteq \text{ span } ( e_1, e_2, \ ... \ ... \ , e_j )$$But ... both lists are linearly independent (x's by hypothesis and the e's by orthonormality ...)
Thus both lists have dimension j and hence they must be equal ...That is $$\text{ span } ( x_1, x_2, \ ... \ ... \ , x_j ) = \text{ span } ( e_1, e_2, \ ... \ ... \ , e_j )
Is that correct ...?
Can someone please critique the above proof pointing out errors and/or shortcomings ...Peter*** EDIT ***
Above I claimed that the the list of vectors $$e_1, e_2, \ ... \ ... \ , e_j$$ was orthonormal ... and hence linearly independent ... but I needed to show that the list $$e_1, e_2, \ ... \ ... \ , e_j $$ was orthonormal ... To show this let $$1 \le k \lt j$$ and calculate $$\langle e_j, e_k \rangle$$ ... indeed it readily turns out that $$\langle e_j, e_k \rangle = 0$$ for all $$k$$ such that $$1 \le k \lt j$$ and so list of vectors $$e_1, e_2, \ ... \ ... \ , e_j$$ is orthonormal ... Peter
