Graph of a particle in parabolic path
In summary, The conversation discusses the representation of a parabolic graph and its relation to potential energy and the actual path of a particle. The question at hand is how to distinguish between two options (a and b) that represent simple harmonic motion in relation to the given graph. The conversation also touches on the initial conditions and the behavior of the particle, which starts from rest and follows a parabolic path. The parabolic shape in the graph represents the variation of potential energy with position. The correct option is determined to be option B, as it represents the cosine curve where the particle is at its extreme position.
Jahnavi
848
102
I don't understand what is y-axis representing ? What is V(x) ? Is it potential energy ?
Since the graph is a parabola , V(x) = kx2
I don't know how to proceed further .
I think it must be, given the choice of answers.
Likes Jahnavi
OK . V(x) is zero (minimum ) at x= 0 . x = 0 represents position of equilibrium .
How to distinguish between a) and b) ? Both represent SHM
The problem says that the particle follows the parabolic path shown, and the arrow points to the initial position of the particle, from where it is released from rest. Which function corresponds to that initial condition?
Likes Jahnavi
The parabolic shape in the graph represents the variation of V(x) with x . It does not represent the path .
Is the parabola representing V(x) or the actual path of the particle ? These two are different things
.Or is that the parabola is representing the actual path as well the variation of potential energy ?
If it is the actual path then option B) makes sense as it represents the cosine curve where particle is as it's extreme position.
"A particle of mass m is released from rest and follows a parabolic path as shown. " What do you think it means?
You can imagine that the particle moves in a well of parabolic cross section. And the potential energy is proportional to the height,
Anyway, the particle starts from rest. Which graphs starts with zero slop?
Likes Jahnavi
Thanks !
Related to Graph of a particle in parabolic path
What is a parabolic path?
A parabolic path is the curved trajectory followed by an object when its motion is influenced by both gravity and a constant horizontal velocity.
What factors affect the shape of a parabolic path?
The shape of a parabolic path is affected by the initial velocity, the angle of launch, and the force of gravity.
How is the graph of a particle in parabolic path represented?
The graph of a particle in parabolic path is typically represented by a parabola, with the x-axis representing time and the y-axis representing the position of the particle.
What does the slope of the graph represent?
The slope of the graph represents the velocity of the particle at a given point in time. The steeper the slope, the higher the velocity.
How can the graph of a particle in parabolic path be used to calculate the maximum height and range of the particle?
The maximum height of the particle can be determined by finding the highest point on the parabolic curve. The range can be calculated by finding the x-intercepts of the parabola, which represent the horizontal distance traveled by the particle.
