MHB Graph of P(x) Under |y| Transformations: a & b
  • Thread starter Thread starter twicesana
    Transformations
The graph of P(x) = 3x + 4 behaves differently under the transformation y = |P(x)| based on the value of y. For y ≥ 0, the graph remains unchanged since the output is already non-negative. However, for y < 0, the transformation reflects the negative portions of the graph above the x-axis, resulting in a V-shaped graph that only shows non-negative values. This transformation effectively eliminates any negative y-values by mirroring them. Understanding these behaviors is crucial for analyzing the effects of absolute value transformations on linear functions.
twicesana
QS: Explain how the graph P(x)=3x+4 behaves under the transformation y=|P(x)| when:
a) y\ge0
b) y<0
I'm not sure how to explain this in words.Thank You!
Mathematics news on Phys.org
a) y\ge0
b) y<0
What is |3|?
What is |-3|?
So given [math]y \geq 0[/math] what happens to |y|? etc.
-Dan
transformation sketch ...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
