Graph or lattice topology discretization
In summary, the conversation revolved around the topic of using lattice models to represent smooth spaces and the challenges that arise with this approach. The person asking for help was unsure about which field of mathematics would be most applicable and mentioned graph theory and topology as possibilities. The experts suggested using discrete exterior calculus to extract geometric information from a simplicial complex and also mentioned the concept of taxicab geometry as a potential solution. The conversation ended with the person expressing their gratitude for the new information and sharing their idea for a potential solution.
diegzumillo
173
Mathematicians, I summon thee to help me identify which field deals with this stuff. I come here not as a physicist but as a sunday programmer trying to solve some numerical problems.
I set out to model a lattice version of a smooth space. A discretization procedure not uncommon in physics, but there's a catch: every connected point has the same distance. Which essentially breaks everything I knew about lattices. So I'm not putting points on a plane (where each point would have its own coordinates) but making a plane out of points. So each point only has has information about its connectivity with its surroundings. This is closer to graph theory, I believe.
This smells a lot like topology, that's why I came here. Is there a way to retrieve information, like number of dimensions, or even geometrical aspects like curvature, in some limit where this graph/lattice tends to a continuum space? This limit would be an increase in number of points or something like that.
Mathematics news on Phys.org
Not an expert, but I don’t think graphs are appropriate structures for most topological or geometric problems. Graphs have only vertices and edges, whereas a triangulation of a topological or geometric space has k-simplices, where k<= the dimension of the space being considered.
I get the distinct impression that you are interested in geometric data and not topological data (that would be invariants like Betti numbers and homology groups and such). If you have a representation of a space as a simplicial complex, you could consider the discrete exterior calculus, but to extract meaningful geometric information I assume you’d some more geometric data, perhaps a metric which assigns edges to their respective distances.
Thanks for pointing to (discrete) exterior algebra. I will have to do some reading to see if that is the way but it's better than what I had before! (nothing)
Likes suremarc
OK, I did some more reading. Exterior algebra is promising but I suspect the solution might be simpler. I found some more fancy words to describe what I was talking about. I learned the concept of taxicab geometry, where distance is defined as an absolute value from point to point. So maybe if I can tesselate a surface in a specific way where the taxicab distance in this lattice approximates the continuum version, that might work.
Anyway, just wanted to do a update/closure to this topic.
Related to Graph or lattice topology discretization
1. What is graph or lattice topology discretization?
Graph or lattice topology discretization is a method used in scientific simulations to divide a continuous domain into smaller, discrete elements. These elements, also known as nodes or vertices, are connected by edges to form a network or graph. This allows for the analysis of complex systems by breaking them down into simpler components.
2. How does graph or lattice topology discretization work?
This method works by creating a grid-like structure over the domain of interest, with each node representing a point in space. The connections between nodes form a network or lattice, which can be used to analyze the system's behavior. The size and shape of the grid can be adjusted to suit the specific needs of the simulation.
3. What are the advantages of using graph or lattice topology discretization?
There are several advantages to using this method. Firstly, it allows for the simulation of complex systems by breaking them down into smaller, more manageable components. It also allows for the incorporation of boundary conditions and other constraints into the simulation. Additionally, the use of a grid structure allows for efficient computation and analysis.
4. What are the limitations of graph or lattice topology discretization?
One limitation of this method is that the accuracy of the simulation depends on the size and shape of the grid used. A very fine grid may result in a more accurate simulation, but it also requires more computational resources. Additionally, this method may not be suitable for systems with irregular or non-uniform structures.
5. What are some examples of applications for graph or lattice topology discretization?
This method is used in various scientific fields, such as physics, chemistry, and engineering. It can be used to model fluid flow, heat transfer, and chemical reactions, among other things. It is also commonly used in computer graphics and image processing to analyze and manipulate digital images.
  • Linear and Abstract Algebra
  • General Math
  • General Math
