Graph r = 6 cos() issues with plotting on xy-plane
In summary, the conversation discusses how to graph the polar equation r = 6 cos(θ) on the θr-plane and the xy-plane. The first part explains that as θ ranges from 0 to π/2, r ranges from 6 to 0 and the curve starts at 6 units from the origin on the positive x-axis and gradually returns to the origin by the time the curve reaches the y-axis. In the second part, as θ ranges from π/2 to π, the r values are all negative and the graph is plotted in Quadrant IV, with all angle rotations starting from the negative x-axis. The third part mentions that as θ ranges from π to 3π/2,
Vital
108
Hello!
Last week I have came here for the help related to this problem. I am creating a new thread to describe the issue more precisely. I will be grateful for your help and explanation.
I post the explanation for the book first accompanied by attached pictures, and below I post my questions.
Example on how to graph the polar equation
r = 6 cos(θ)
Quote part 1:
We graph one cycle of r = 6 cos(θ) on the θr-plane and use it to help graph the equation on the xy-plane. We see that as θ ranges from 0 to π/2 , r ranges from 6 to 0. In the xy-plane, this means that the curve starts 6 units from the origin on the positive x-axis (θ = 0) and gradually returns to the origin by the time the curve reaches the y-axis (θ = π/2 ). The arrows drawn in the figure below are meant to help you visualize this process. In the θr-plane, the arrows are drawn from the θ-axis to the curve r = 6 cos(). In the xy-plane, each of these arrows starts at the origin and is rotated through the corresponding angle , in accordance with how we plot polar coordinates.
End of the quote part 1.
Picture attached.
Quote part 2:
Next, we repeat the process as θ ranges from π/2 to π. Here, the r values are all negative. This means that in the xy-plane, instead of graphing in Quadrant II, we graph in Quadrant IV, with all of the angle rotations starting from the negative x-axis.
End of the quote part 2.
So, if θ = 3π/4, then r = -3√2
θ = π , then r = -6
In the first part we started at the angle θ = 0 and thus r = 6, which we plotted as x = 6; then rotating counter-clockwise as all values of r become smaller as θ approaches π/2. This is clear to me.
And now I am confused by the second part. It is said that r values are negative, so I don't understand why we plot these values along the positive x-axis and rotate clockwise. How did they come up with this rotation, what is the reason that I fail to understand? The phrase on the picture saying "r < 0 so we plot here" gives a sense that this is obvious, but not to me. Please, help me to understand it.
It seems they are plotting absolute values of r along x-axis, so all x values are positive. But how's this justified mathematically?
Here is also the next, even more confusing, quote:
As θ ranges from π to 3π/2, the r values are still negative, which means the graph is traced out in Quadrant I instead of Quadrant III.
End of quote.
Interesting. The second part stated that as values of r are negative, we have to plot in QIV; and the third quote says that as values are still negative, we obviously have to plot in QI. I am utterly confused. :) Please, help.
Thank you very much!
I wouldn't say that. It looks like they are plotting points on the line through the origin at angle θ, where positive r is in direction θ and negative r is in the opposite direction. The arrow lines show the direction that the point is in from the origin.
But:
(1) when the interval is [0, π/2] and r = 6, they start at y = x = 6 and go all the way "up" (counter-clockwise) till angle reaches π/2; it's clear;
(2) when the interval is [π/2 , π] and the value of r = -6 at angle π, they most likely start at the angle -π/2, move counter-clockwise "up" till 2π, and surprisingly end at y = x = 6, not x = -6;
(3) and then, when even more puzzling thing happens - even though values are still negative and interval is [π, 3π/2], they get back to the interval [0, π/2] in QI;
(4) and for the last interval of [3π/2, 2π], they get back to QIV.
I genuinely don't get it. It seems there is something very easy-peasy in all this, some very basic notion that I miss.
Vital said:
But:
That is not what it says in part 2. They say they are measuring the angle (still counter-clockwise, I assume) starting on the negative x-axis. That puts them in quadrant IV. I prefer to think of it as measuring the angle as always (so still in quadrant II) and negative r points in the opposite direction through the origin, putting you in quadrant IV.
Same as in (2). Since r is negative, they are measuring their angle counter-clockwise starting on the negative x axis. That pits them in quadrant I. As before, I prefer to think of it as measuring the angle as always (so still in quadrant III) and negative r points in the opposite direction through the origin, putting you in quadrant I.
Their approach for positive r measures the angle normally (counter-clockwise starting from the positive x axis), which puts them in quadrant IV.
Likes Vital
From another perspective, it's possible to convert the equation ##r = 6\cos(\theta)## to Cartesian form.
First step: Multiply both sides by r, to get ##r^2 = 6r\cos(\theta)##.
Doing this adds a solution r = 0, but in the original equation, when ##\theta = \pi/2##, r = 0, so we're not adding a solution that wasn't already there.
Now convert ##r^2 = 6r\cos(\theta)## to Cartesian (or rectangular) form, resulting in ##x^2 + y^2 = 6x##. By completing the square in the x terms, it's fairly easy to show that the equation represents a circle.
Sorry, but you took a wrong direction. I am happy because now I have an explanation. In fact it's much easier: when r is negative, we sort of flip all values 180 degrees.
How so?
In post 1, you have the following in your Relevant Equations section:
r = 6 cos(θ)
My explanation gave an alternate way to get the graph directly.
That's not what FactChecker was saying in post 4.
Good. But you should understand their approach because they might use it again later (maybe for other things).
Of course. :-) It is a normal approach for such polar equations: whenever r<0, we first go r values on the usual θ ray, and then add π, namely go 180 on the opposite direction. That is why when r < 0 and θ is, say, in QII, that means we plot that part in QIV; if θ is in QIII and r < 0, we plot in QI. This is what I missed, and hence didn't understand all those steps, described in quotes in the original message. And, actually, this is exactly what you have said in your post above. :-)
Oh! Of course! They are just adding the 180 at the beginning rather than at the end. I didn't see that.
Related to Graph r = 6 cos() issues with plotting on xy-plane
1. What does the equation "r = 6 cos()" represent in the context of graphing on the xy-plane?
The equation "r = 6 cos()" represents a polar equation in which the distance from the origin (r) is equal to 6 times the cosine of the angle (θ). This equation can be used to plot points on a polar coordinate system.
2. How do you plot points from a polar equation on the xy-plane?
To plot points from a polar equation on the xy-plane, you can use the following steps:1. Convert the equation to rectangular form using the conversion formulas: x = r cos(θ) and y = r sin(θ).2. Choose values for θ and use the equation to calculate the corresponding values for x and y.3. Plot the points (x,y) on the xy-plane.4. Repeat for different values of θ to create a curve.
3. What issues can arise when plotting a polar equation on the xy-plane?
One issue that can arise when plotting a polar equation on the xy-plane is the presence of multiple values for a given angle. This can result in overlapping points and a distorted graph. Another issue can be understanding the behavior of the graph for different values of θ, which may require manipulating the equation or using a graphing calculator.
4. How can the graph of "r = 6 cos()" be interpreted?
The graph of "r = 6 cos()" represents a circle with center at the origin and a radius of 6. The cosine function causes the graph to oscillate between positive and negative values, resulting in a flower-like shape with six petals. The angle θ can be interpreted as the direction in which the circle is being traced, with θ = 0 representing the rightward direction.
5. What are some real world applications of using polar equations and graphing on the xy-plane?
Polar equations and graphing on the xy-plane have various real world applications, including:- Mapping out the trajectory of a planet or satellite in space.- Representing the motion of a pendulum or other oscillating system.- Plotting the path of a hurricane or other circular storm system.- Creating designs in circular or rotational symmetry, such as flower patterns or kaleidoscopic images.- Modeling the growth patterns of certain plants or organisms that exhibit circular growth.
