Graph Theory: (proof)conditions for Euler Circuit in Digraph
In summary: A directed graph has an Eulerian circuit if and only if it is connected and each vertex has the same in-degree as out-degree. Therefore, the state of being connected is a necessary condition for the existence of an Eulerian circuit. Your example graph does not satisfy the condition of being connected, as it contains a zero degree vertex. This condition is essential for the existence of an Eulerian circuit, as it ensures that all vertices will be visited and all edges will be used exactly once, fulfilling the definition of an Eulerian circuit.As for the mathematical proof, it involves showing that the existence of an Eulerian circuit implies the conditions stated in the theorem, and vice versa. This involves using the properties of connected graphs, strongly connected components, and
lem0ncheezcake
I have read in many places that one necessary condition for the existence of a Euler circuit in a directed graph is as follows.
Theorem: "A directed graph has an eulerian circuit if and only if it is connected and each vertex has the same in-degree as out-degree."
However, I don't understand why the state of being connected is a necessary condition. I thought that a Euler circuit is a closed walk where all of the edges are distinct and uses every edge in the graph exactly once. Therefore, the disconnected graph shown below should satisfy the condition of being a Euler circuit. (All the edges in the graph are used exactly once).
Can anyone explain what I did wrong here? Also it would be greatly appreciated if someone could give a mathematical proof to both parts of the theorem.
Thanks!
Mathematics news on Phys.org
Your example graph contains a zero degreed vertex, one of whose properties your quoted theorem is still missing.
  • A directed graph has an Eulerian cycle if and only if every vertex has equal in degree and out degree, and all of its vertices with nonzero degree belong to a single strongly connected component. Equivalently, a directed graph has an Eulerian cycle if and only if it can be decomposed into edge-disjoint directed cycles and all of its vertices with nonzero degree belong to a single strongly connected component.
Eulerian path and cycle or circuit.
Related to Graph Theory: (proof)conditions for Euler Circuit in Digraph
1. What is a Euler circuit in digraph?
A Euler circuit in a digraph is a path that visits every vertex exactly once and ends at the starting vertex. It is also known as a closed walk or a circuit.
2. What are the conditions for a digraph to have an Euler circuit?
The two main conditions for a digraph to have an Euler circuit are:
  1. Every vertex in the digraph must have an equal number of incoming and outgoing edges.
  2. The digraph must be connected, meaning there is a path between any two vertices.
3. How do you prove the existence of an Euler circuit in a digraph?
To prove the existence of an Euler circuit in a digraph, you must show that it satisfies the two conditions mentioned above. This can be done by using the Handshaking Lemma, which states that the sum of the degrees of all vertices in a graph is equal to twice the number of edges.
4. Can a digraph have more than one Euler circuit?
Yes, a digraph can have multiple Euler circuits as long as it satisfies the two conditions mentioned above. In fact, if a digraph has one Euler circuit, it will have infinitely many Euler circuits.
5. Are there any real-world applications of Euler circuits in digraphs?
Yes, Euler circuits have many real-world applications, including in transportation networks, circuit design, and computer algorithms. For example, in a transportation network, an Euler circuit could represent the most efficient route for a delivery truck to visit all necessary locations.
  • Electrical Engineering
