Graphical Transformation of y=ln (x)
  • Thread starter Thread starter AN630078
    Transformation
The discussion focuses on the graphical transformations of the functions y=ln(2x) and y=ln(4-x). It is noted that y=ln(2x) represents a horizontal stretch of y=ln(x) with a scale factor of 1/2, as each x-value is multiplied by 2 before calculating the y-value. For y=ln(4-x), it is described as a reflection in the y-axis followed by a translation, specifically moving the graph left by 4 units rather than right. Clarification is sought on whether the transformations refer to the graph line or the x-axis. The conversation emphasizes the importance of accurately describing these transformations in relation to the coordinate system.
AN630078
Hello, I was practising describing graphical transformations with several example questions but there was one which I was especially unsure of. I would appreciate any advice upon my proposed solutions.
Describe the transformation which maps y=ln(x) to;
a. y=ln(2x)
b.y=ln(4-x)
y=f(ax) is a horizontal stretch by a scale factor 1/a
y=f(-x) is a reflection in the y-axis
y=f(x+a) is a translation by the vector (-a,0)
a. I believe that y=ln(2x) is a horizontal stretch of y=ln(x) of scale factor 1/2. In the transformation y=ln(2x), each x-value is multiplied by 2 before the corresponding y-value is calculated.
b. I think that y=ln(4-x) is a reflection in the y-axis followed by a translation by the vector (-4,0) i.e. 4 units to the right.
Just to be clear, you need to say if you are talking about the x-axis being stretched and reflected or about the graph line.
Try reducing that to one operation.
If we take the relevant equations as the guide, it must mean a transformation of the curve, keeping the coordinates fixed.
I would not say that a translation"by the vector (-4,0)" is "4 units to the right." I would say that it is moving the points of the graph line to the left versus the axis system.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
