MHB Graphically solving 2X2 linear system and finding the line through 2 points
The discussion focuses on solving a system of linear equations graphically and finding the equation of a line through two points. The user solved the equations y = -4x + 2 and x - 2y = 10, arriving at the solution x = 1.55 and y = -4.22, which was confirmed as correct. Additionally, the user found the equation of the line passing through the points (4, -2) and (0, 6) as y = -2x + 6, which was also validated as correct. The thread highlights the importance of peer verification in solving mathematical problems.
drop
Basically I don't know anyone in real life that can help me with this, so I need help checking to see if my answers are correct :)
PART A
1) Using a graphing utility solve the following system of linear equations. Round your answer to the nearest hundredth.
y = -4x+2
x - 2y = 10
My answer: x = 1.55 y = -4.22
2) Find the equation of the line that passes through the points (4,-2) and (0,6)
My answer: y = -2x + 6
Mathematics news on Phys.org
Re: Please check my answers - 1
Right.
Right.
Thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
