MHB Graphing Trig Function: Amplitude 4, Period (2\pi/3), Range [-4,4]
The discussion focuses on graphing the trigonometric function f(x)=4sin(3x-2) with an amplitude of 4, a period of (2π/3), and a range of [-4,4]. Participants emphasize the importance of graphing over two periods and identifying nine key points, including the function's maximum, minimum, and zero crossings. A suggested approach involves rewriting the function to highlight its phase shift and determining the appropriate domain for one period. The conversation includes calculating specific x-values for the graph and encourages further exploration to complete the nine points needed. Overall, the thread provides guidance on effectively visualizing the function's behavior.
Dasysaaaa
I need some help graphing this trig function.
f(x)=4sin(3x-2)
When Graphing, the points should be over 2 periods and 9 points.
I have:
-Amplitude: 4
-Period=(2\pi/3)
-Range=[-4,4]
I need help on:
-Graphing the points over 2 periods and 9 periods (parent function and f(x))
-Table of 9 points (f(x) and parent function)
-Increments (f(x) and parent function)
Thank You in advance if You can help me!(Blush)
Mathematics news on Phys.org
I agree with what you've done so far regarding the amplitude, period and range. Now, if I were going to sketch a graph of $f(x)$, I would write it in the form:
$$f(x)=4\sin\left(3\left(x-\frac{2}{3}\right)\right)$$
In this form, we can see that $f$ is shifted $$\frac{2}{3}$$ units to the right compared to $y=4\sin(3x)$. Now, if I was going to graph $f$ over just one period, I would choose the domain:
$$\left[\frac{2}{3},\frac{2}{3}(\pi+1)\right]$$
On this domain, the sinusoid described by $f$ will begine at 0, movie to to 4, then back down to 0, continue down to -4, then move back to to 0, completing 1 cycle.
I would divide this domain into 4 subdivisions of equal width corresponding to the extrema and equilibria (that is, the zero, maximum and minimum values for $f$). This gives us the $x$-values:
$$x=\frac{2}{3}+\frac{k}{4}\cdot\frac{2}{3}\pi=\frac{2}{3}+\frac{k}{6}\pi$$ where $k\in\{0,1,2,3,4\}$
Putting all this together, this gives us the 5 points:
$$\left(\frac{2}{3},0\right),\,\left(\frac{2}{3}+\frac{1}{6}\pi,4\right),\,\left(\frac{2}{3}+\frac{1}{3}\pi,0\right),\,\left(\frac{2}{3}+\frac{1}{2}\pi,-4\right),\,\left(\frac{2}{3}+\frac{2}{3}\pi,0\right)$$
If you continue for another period, this would give you 4 more points for a total of nine...can you continue?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
