Graviational Field of Floating Mountain
In summary, the problem discusses a spherical mountain floating in equilibrium on the Earth's surface with a density half that of the Earth's. The task is to find the difference between the Earth's gravitational field intensity at its surface and at the top of the mountain. By using the concept of superposition, it is determined that the difference is equivalent to the field of a thin disk with a radius equal to the mountain's and a surface density equal to the Earth's volume density at a distance a from the center of the disk.
chrisk
288
Consider a spherical mountain of radius a, mass M, floating in equililbrium in the earth, and whose density is half that of the earth. Assume that a is much less than the Earth's radius, so that the Earth's surface can be regarded as flat in the neighborhood of the mountain. If the mountain were not present, the graviational field intensity near the Earth's's surface would be g0. Find the difference between g0 and the actual value of g at the the top of the mountain.
Knowledge of Lagrangian Mechanics is not required. I determined the mountain is half submerged below the Earth's surface and g0 is independent of height (infinite disk). I attempted solving for the g field of a hemisphere but the intergral was not a form that could be solved without binomial expansion. The answer provided in the back of the text is
g0 - g = (GM/a^2)(2 - sqrt(2))
I noted the answer is equivalent to a thin disk of radius a, mass M, with surface density equal to the Earth's volume density at a distance a from the center of the disk along the disk axis. So, somehow superposition shows the equivalence. Any hints are appreciated.
I solved the problem. A matter of superposition of fields at the point in question. Key was finding the field due to a solid hemisphere a distance a from the flat surface of the hemisphere.
FAQ: Graviational Field of Floating Mountain
1. What is a "Gravitational Field of Floating Mountain"?
A "Gravitational Field of Floating Mountain" is a hypothetical scenario in which a mountain, or any other large object, is floating in the air due to the presence of a strong gravitational field. This concept is often used in science fiction and is not possible in our current understanding of physics.
2. How does a "Gravitational Field of Floating Mountain" occur?
As mentioned before, a "Gravitational Field of Floating Mountain" is not possible in our current understanding of physics. In order for an object to float, there must be a force acting on it that is equal to or greater than the force of gravity pulling it down. This is not possible for a large object like a mountain, as the force of gravity is too strong.
3. Can a "Gravitational Field of Floating Mountain" exist on Earth?
No, a "Gravitational Field of Floating Mountain" cannot exist on Earth. As mentioned before, the force of gravity on Earth is too strong for a large object like a mountain to float. In addition, the Earth's atmosphere and other forces such as wind and air pressure would prevent a mountain from floating.
4. Could a "Gravitational Field of Floating Mountain" exist on another planet?
It is highly unlikely that a "Gravitational Field of Floating Mountain" could exist on any other planet in our solar system. Each planet has its own unique gravitational force, and it is not possible for a mountain or any other large object to float in the air due to these forces. However, there may be other planets or moons in the universe with different physical properties that could potentially allow for this scenario to occur.
5. What are the implications of a "Gravitational Field of Floating Mountain"?
The implications of a "Gravitational Field of Floating Mountain" are purely hypothetical and often used in science fiction. In reality, it is not possible for a large object like a mountain to float in the air due to the strong force of gravity. However, studying this concept can help us better understand the laws of physics and the limitations of our understanding.
