Gravimetric Analysis- precipitation method
In summary: From the equation, I assumed a 1:1 ration between AgCl and the hydrated chloride. Hence, no. of mols hydrated chloride = 8.58x10^-3.To calculate the mass of Cl, you would use the no. of mols as 8.58x10^-3. This would give a mass of 0.305g.You could also use this mass to calculate the percentage of Cl in the original chloride - you were given the mass, and you can be sure 0.305g is also a mass of chlorides in the original sample. There is no other source of chlorides.
leah3000
43
1.046g of the hydrated chloride of a certain metal were dissolved in water and silver chloride was precipitated by the addition of a slight excess of silver nitrate solution. After purification the silver chloride had a mass of 1.231g. Calculate the percentage of chlorine in the hydrate. If it is of the form, MCl2.2H2O, calculate the relative atomic mass of the metal, M.
My attempt at a balanced equation for this:
XCl.xH2O + H2O + AgNO3 ---> AgCl + XNO3
not sure if that's correct
no. of mols AgCl produced = Mass/ Mr = 1.231/(108)+(35.5) = 8.58x 10^-3 mols AgCl
I was trying to calculate the Mr of the hydrated chloride but how do i calculate this if i have 2 variables? The mass of the element X and the no. of mols of water?
I was thinking i'd need to calculate the Mr and then divide the mass of chlorine by the Mr of the compound...then multiply by 100 to find the %:confused:
Can someone please help me!
You are making it harder than it really is. What is mass of chlorine in 1.231g of AgCl? Once you know mass of Cl, calculating its percentage is a breeze.
Now, how many moles of Cl? How many moles of MCl2? Molar mass of MCl2.2H2O? Molar mass of M?
methods
chemical calculators - buffer calculator, concentration calculator
www.titrations.info - all about titration methods
ok so to calculate the mass of Cl do i still use the no. of mols as 8.58x10^-3? which could then give a mass of 0.305g?
Also if i use this mass to calculate the percentage of Cl, wouldn't that give me the percentage in AgCl (24.8%)? So then do i just subtract this from 100 to get the percentage in the hydrated halide (75.2%)?
I'm really not sure about this...can u explain the MCl2.2H2O part please.
This is correct mass of chlorine.
You can as well use this mass to calculate percentage of chloride in the original chloride - you were given the mass, and you can be sure 0.305g is also a mass of chlorides in the original sample. There is no other source of chlorides.
No, that's completely off and these numbers are unrelated. When it comes to percentages you need to look at each compound separately.
Try to answer questions I have already asked (in the order they were asked, using answer to the previous one to find answer to the next). How many moles of Cl? How many moles of MCl2? Molar mass of MCl2.2H2O? Molar mass of M?
I would approach this problem by first checking the balanced equation, which is correct. Then, I would use the given masses of the hydrated chloride and the resulting silver chloride to calculate the number of moles of chlorine present in the original compound. This can be done by dividing the mass of silver chloride by its molar mass (108.5 g/mol) and multiplying by the molar ratio between chlorine and silver chloride (1:1).
Next, I would use this number of moles of chlorine to calculate the molar mass of the original hydrated chloride compound. This can be done by dividing the mass of chlorine (from the previous step) by the number of moles of chlorine and then adding the molar mass of water (18 g/mol) for each mole of water in the compound.
Finally, to calculate the percentage of chlorine in the hydrated chloride, I would divide the mass of chlorine (from the previous step) by the molar mass of the original compound and multiply by 100. This will give the percentage of chlorine in the compound.
To find the relative atomic mass of the metal, M, we can use the molar mass of the original compound (calculated in the previous step) and subtract the mass of chlorine (35.5 g/mol) and the mass of water (18 g/mol) for each mole of water in the compound. This will give us the mass of the metal in one mole of the compound, which can then be converted to the relative atomic mass of the metal.
Overall, gravimetric analysis using the precipitation method is a reliable and accurate technique for determining the composition of a compound. However, it is important to carefully consider the stoichiometry of the reaction and to perform multiple trials to ensure accurate results.
Related to Gravimetric Analysis- precipitation method
1. What is gravimetric analysis and why is it used?
Gravimetric analysis is a quantitative method used in analytical chemistry to determine the amount of a substance present in a sample by measuring its mass. It is used because it is a precise and accurate method that can be applied to a wide range of substances.
2. What is the precipitation method in gravimetric analysis?
The precipitation method involves separating the analyte (substance of interest) from a solution by adding a precipitating agent, which causes the analyte to form a solid precipitate. The mass of the precipitate can then be measured to determine the amount of analyte present.
3. What are the steps involved in a gravimetric analysis using the precipitation method?
The steps typically involved in a gravimetric analysis using the precipitation method include: preparing a sample, adding a precipitating agent, filtering the precipitate, washing and drying the precipitate, and finally weighing the precipitate to determine its mass.
4. What factors can affect the accuracy of gravimetric analysis using the precipitation method?
Some factors that can affect the accuracy of gravimetric analysis using the precipitation method include the purity of the reagents and equipment used, the temperature and pH of the solution, and the presence of interfering substances in the sample. Proper technique and careful calculations are also important for obtaining accurate results.
5. What are the limitations of gravimetric analysis using the precipitation method?
One major limitation of gravimetric analysis using the precipitation method is that it is a time-consuming process. It also requires a relatively large sample size in order to obtain accurate results. Additionally, the method may not be suitable for substances that are not easily precipitated or for substances that exist in very low concentrations.
15K
22K
