Gravitation - gravity force, centripetal aceleration, work
In summary: The question seems to be asking for a calculation rather than a straightforward explanation.In summary,The two rocks have the same potential energy, because they have the same mass and the same height from the ground.
joanneadams
1Problem:
Two equal satellite, A and B, of a planet of mass M, describe circular trajectories where the radious are 0,5r and r. We can afirm that:
A- The intensity of gravitical force acting on B is half of the gravitical force acting on A;
B- The value of centripetal aceleration of A is one quarter of the value of centripetal aceleration of B.
C- The gravitic potencial energy of the sistem planet+B is double of the gravitic potential energy of the sistem planet+A.
D The work done by the gravitical force, during a complete turn, to satellite A is doubble of the work done by satelite B.
Useful equations:
Fg=G x (mM)/r2
ac=GM/r2
Epg=-GmM/r
Atempt of solution:
I think the right answer is option D.
A- is wrong because it's not half, is one quarter
B.- It's wrong because it's not one quarte, its four times
C- I think it's wrong because it's one half, and not double
D- Both of them are zero, and tecnically 0 times 2 is zero
But my teacher says it's option C, because she says is a negative number. I don't agree with her because, if we do the math we get Epg(B)=1/2Epg(A). why am i wrong, how can C be the right option?
Thank you, for your atention and sorry for the bad english...
Two equal masses (##m_A =m_B##), let's say rocks, are located at different heights (##h_A, h_B##) from the ground, where ##2\cdot h_A =h_B##. Which of them would you expect to have a higher potential energy?
Hi joanneadams,
Welcome to Physics Forums!
Like you I don't see what the sign has to do with it! I agree with you on that point.
Regarding choice D, with the works both being zero it is meaningless to claim that one is twice the other. If you did allow that you could prove that any number is equal to any other number; you'd "break" mathematics :smile:
Likes joanneadams
At face value, C is ill defined unless you also specify the reference level. With the reference level at infinity, B (assuming it is the satellite further away) will have a larger potential than A and indeed, since the numbers are negative, you will obtain ##V_A = 2V_B##.
When it comes to D, I agree with you. Since the work is zero in both cases, the work done on A will indeed be twice the work done on B since ##2\cdot 0 = 0##.
Likes joanneadams
I disagree. Zero is exactly the same as two times zero. The statement as given is clearly true. If you take the work done on B and multiply it by two, you get a number that is the work done on A. In other words, ##x = y = 0## is a valid solution to the equation ##y = 2x##, which the given statement translates to.
Likes joanneadams
Fine. I stand corrected.
I think that, on the whole, the question is poorly designed and presented.
Likes joanneadams
On this, I definitely agree.
Likes joanneadams
Related to Gravitation - gravity force, centripetal aceleration, work
1. What is gravitation?
Gravitation, also known as gravity, is a natural phenomenon by which all objects with mass are brought towards each other. It is the force that holds planets in orbit around the sun and keeps objects on Earth from floating away.
2. How does gravity force work?
Gravity force is a force of attraction between two objects with mass. The strength of the force depends on the mass of the objects and the distance between them. The greater the mass of the objects, the stronger the force, and the greater the distance between them, the weaker the force.
3. What is centripetal acceleration?
Centripetal acceleration is the acceleration that a body experiences when it moves in a circular path. It is always directed towards the center of the circle and is caused by the force of gravity or other centripetal forces acting on the body.
4. How is gravity related to work?
Gravity is related to work through the concept of potential energy. When an object is lifted against the force of gravity, work is done and the object gains potential energy. This potential energy can then be converted back into kinetic energy as the object falls back to its original position.
5. What is the universal law of gravitation?
The universal law of gravitation, formulated by Sir Isaac Newton, states that every object in the universe is attracted to every other object with a force that is directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
