Gravitation potential and gravitational binding energy
In summary: I'm assuming that the equation you are referring to is the one that states:U=-alphaGM^2/RYes, this is the equation that states the gravitational binding energy of a system is equal to the negative of the total gravitational potential energy.
shounakbhatta
288
Hello,
The gravitational binding energy of a system is equal to the negative of the total gravitational potential energy.
Is this given by the equation:
U=-alphaGM^2/R
where alpha=3/5 and the equation stands as:
U=-3/5GM^2/R?
Kindly correct me if I am wrong?
Where did you get the factor of 3/5 from? There is no [itex]\alpha[/itex] = 3/5 in gravitational potential
The gravitational potential energy is:
[itex]\frac{-GMm}{r^2}[/itex]
The gravitational binding energy can be thought of as an internal potential energy. How much grav potential is stored in an object? You must compute the gravitational potential for every particle in the object relative to all the rest of them which simply yields
[itex] \frac{-GM^2}{r^2}[/itex]
Because m is now M. Both values are negative, by convention.
For a spherical mass of uniform density, the gravitational binding energy U is given by the formula
u=3GM^2/5r. The derivation follows from the volume of the sphere, 4 pi r^3 and area of the sphere 4 pi r^2.
In Faber Jackson relation the gravitational potential of a mass distribution of radius R and mass M is given by the expression:
U=-alphaGM^2/R
U=-3/5GM^2/R
So I asked you the above question.
Was this a typo? The gravitational force varies as [itex]1/r^2[/itex] but the gravitational potential energy as 1/r, the integral of [itex]1/r^2[/itex].
Ah, right. I forgot about the factor for the sphere. And yes, the r^-2 factor was a typo.
So,
My question still stands:
U=-alphaGM^2/R
U=-3/5GM^2/R?
Thanks.
Yes, this is true if the mass is uniformly distributed in a sphere. This is analogous to the electrostatic potential energy of a sphere with uniform charge density, which also has a factor of 3/5:
http://farside.ph.utexas.edu/teaching/em/lectures/node56.html
(in particular equation 601 and the derivation preceding it)
Sorry, I was confused at to what the question was. Were you asking if your equation was correct? Because yes, it is.
Except, it's not equal to the NEGATIVE of the total gravitational potential energy, because gravitational potential is also negative. Both quantities are negative, it's just the gravitational binding the the total internal gravitational potential of the object.
Reading over Wikipedia I found that:
U=3GM^2/5R
Again it states that for a uniform sphere the gravitational binding energy of the sphere is the negative of the gravitational potential energy, which is:
U=-3GM^2/5R
Are they referring to the same equation? How can one equation have different results?
Binding energy is the energy that we must add to a bound system in order to separate it completely into its constituents. It is always positive. If it were negative, the system could fly apart by itself, releasing energy. For a gravitationally bound sphere with uniform density, it is Eb = 3GM2/5R.
When we add energy to a system, we increase its (potential + kinetic) energy. If the kinetic energy of the "pieces" is zero before and after, then only the potential energy changes. Ubound + Eb = Useparated. In the situation that we're dealing with here, we define the potential energy to be zero when the system is completely separated, that is, Useparated = 0.
This leads to Ubound = -Eb = -3GM2/5R.
The negative signs are more a thing of convention than anything...
I think what jtbell wrote is useful. Often, an object in a bound state, like an atom in a ground state, or a spherical planet, must be at a minimum of potential energy.
The easiest way to do this is to say that a potential energy of zero means the system is totally unbound (imagine an ionized atom), and obviously, the bound state would have to have a negative energy, -3GM2/5R, for a planet, star, etc.
You can also think of the positive of this as being the energy required to unbind the system, so the energy needed to ionize an atom, or the energy required by the Death Star to disintegrate Aldreraan ;)
There is an arbirarity to potential energy. You can set the zero point energy to be anything as long as you are consistent. There are standard conventions for some systems like gravitational binding energy that make everything much nicer, however.
I'm guessing this is the wiki page you're referencing?
http://en.wikipedia.org/wiki/Gravitational_binding_energy
I see that they use the positive and negative version of the equation. It makes little difference. It only matters the convention. The top equation is essentially saying that this is the energy stored in the gravitational binding of the object, and the second equation is saying that this is the total binding potential of the spherical object , which is negative if we say that the potential zero point is when the system is completely unbound.
How do you deal with the gravitational self-energy of a point mass? Renormalization?
Thank you jtbell, for your wonderful reply. It just cleared out all my confusions.
Thank you soothsayer. Yes, you are very right. I was referring to the wikipedia article only. Thanks for the detailed reply on the topic. Thanks.
Thank you all.
It's just GM2/R, I believe. Integrating over a sphere gives 3GM2/5R.
point mass has no R
FAQ: Gravitation potential and gravitational binding energy
What is gravitational potential?
Gravitational potential is a measure of the potential energy an object has due to its position in a gravitational field. It is directly related to the strength of the gravitational force between two objects, with higher potential indicating a greater force.
How is gravitational potential calculated?
Gravitational potential is calculated using the equation V = -GMm/r, where V is the gravitational potential, G is the gravitational constant, M and m are the masses of the two objects, and r is the distance between them.
What is gravitational binding energy?
Gravitational binding energy is the amount of energy required to completely separate two objects that are held together by gravity. It is a measure of the strength of the gravitational force between the two objects.
How is gravitational binding energy related to gravitational potential?
Gravitational binding energy is directly related to gravitational potential, as it is a measure of the potential energy that is keeping two objects bound together in a gravitational field. The higher the gravitational potential, the greater the binding energy.
Why is understanding gravitational potential and gravitational binding energy important?
Understanding gravitational potential and gravitational binding energy is important in many areas of science, such as astrophysics and engineering. It allows us to understand the behavior of objects in a gravitational field and make accurate predictions about their movements and interactions.
