What Are the Gravitational and Normal Forces on a Skier on a Slope?
In summary, a 60 kg skier is starting to ski down a 26 degree slope with a frictional force of 4 N. The gravitational force exerted by the skier on the slope can be calculated by multiplying the skier's mass, the acceleration due to gravity, and the cosine of the slope angle, which results in 528.5 N. The normal force exerted by the slope back on the skier can be found by using a free-body diagram and considering that there is no acceleration in the vertical direction, making the normal force equal to the gravitational force.
j doe
37
A 60 kg skier is beginning her descent down a 26 degree slope. The frictional force between the skis and the snow is 4 N
a) What is the gravitational force the skier exerts on the slope?
b) What is the normal force the slope exerts back on the skier?
60(kg)*9.8(m/s^2)*cos(26) = 528.5(N)
not sure how to do this one
First, sketch a free-body diagram. Use the slope as the X axis. Since there is no acceleration in the Y axis of this system, you can solve for the normal force.
did i do part a correctly?
As there is no acceleration in the Y axis, it means the force exerted by the skier on the slope and the one the slope exerts on the skier is the same. It's kind of the definition of the normal force, it is a force exerted by the surface on the object, it is a force of reaction to another one, which here is the gravitational force.
Is that the word-for-word statement of the question? It doesn't make any sense.
The Earth exerts a gravitational force on the skier, and the skier exerts an equal and opposite gravitational force on the Earth; the skier exerts a contact force on the slope, which can be resolved into a combination of forces in different directions, like normal and tangential.
I do not know what "the gravitational force exerted by the skier on the slope" means. Maybe it means the vertical component of the contact force?
Related to What Are the Gravitational and Normal Forces on a Skier on a Slope?
1. What is the difference between gravitational force and normal force?
Gravitational force is the force of attraction between two objects with mass, while normal force is the force exerted by a surface on an object in contact with it.
2. How is the magnitude of gravitational force determined?
The magnitude of gravitational force is determined by the masses of the two objects and the distance between them, as described by Newton's law of universal gravitation.
3. How does normal force act on an object?
Normal force acts perpendicular to the surface an object is in contact with, preventing the object from falling through the surface.
4. Can the direction of normal force ever change?
Yes, the direction of normal force can change if the surface an object is in contact with is not perpendicular to the force of gravity acting on the object.
5. How do gravitational and normal force interact with each other?
Gravitational force and normal force are both vector quantities and can cancel each other out or act in the same direction, depending on the orientation and location of the objects involved.
