Gravitational attraction on the cosmic scale?
In summary, the conversation discusses two views on the net force of gravity in an infinite, perfectly homogeneous universe. View a) suggests that the net force of gravity is zero everywhere, while view b) argues that the net force is only zero within a spherical cavity and non-zero on particles within the cavity. The conversation also touches on the issue of a preferred frame of reference and how the Friedmann equation and its dust term can lead to a contradiction in this scenario. Ultimately, it is concluded that view a) is the correct answer while view b) is a paradox.
  • #36
Exactly: relevant for kinetic energy is relative motion between particles. Nothing else. Speed, and so kinetic energy, of an object in otherwise empty space is non-observable and (therefore) physically meaningless. It needs a second object to become physically meaningful.
Space news on Phys.org
  • #37
Bill_K said:
Don't you recognize it? It's a standard paradox. Nothing to do with cosmology or general relativity, it results from attempting to apply theorems relating to Laplace's Equation to a source with an infinite uniform distribution. It can be the Newtonian gravitational potential of a mass distribution, the electrostatic potential of a charge distribution, etc. (a) of course is the correct answer.
Bill_K, could you elaborate on this? What standard paradox are you referring to? Any references?
  • #38
Nope. Especially not in a curved space-time (e.g., an expanding universe), where the definition of the relative velocity of two far-away particles is arbitrary.
Here the only reason kinetic energy was brought up in the first place was in the context of a thermal fluid where the pressure of the fluid is proportional to the average kinetic energy of the particles that make up said fluid. The average motion of the fluid plays no role whatsoever in determining this pressure: it is only the relative motions of the individual particles. So the correct frame of reference is the comoving frame.
  • #39
The universe appears flat, not? GR is a local theory, therefore may have/has difficulties with non-local relationships. The ambiguity this causes in concepts like kinetic energy and gravitational potential make some people make statements like these concepts do not exist on cosmic scales. Or become nill, as you see it wrt kinetic energy. At what distances these elementary concepts cease to exist or vanish? There is no clear transition between bound and unbound matter.
I understand pressure of a fluid is related to the average kinetic energy of the particles, but this is thermal (random) motion. Uniform recessional motion like in the universe is without collisions, i.e. no thermal pressure. But why would this not carry kinetic energy? Again, imagine what happens in a big crunch. No energy?
  • #40
Flat space, curved space-time. The curvature that we see manifests itself as the expansion of our universe.
That's not really relevant to the issue. All of our theories of physics are local (or can be written down in a local manner). They usually don't have this peculiar issue of not being able to compare velocities of far-away objects.
And that's why recession velocity doesn't play a part in pressure.
Again, context. Sure, you can define a kinetic energy that these particles would have, but it's a definition that is meaningless in the context of this discussion.
  • #41
Chalnoth said:
Again, consider a finite sphere of matter, instead of the force a single particle feels.
Chalnoth, this coincides with view b) in my original post, if I am right. I suppose you also agree with view a) (net force zero)? Then would you state that both views hold, i.e. there is no paradox?
  • #42
Sorta kinda. It coincides with the statement that there is no net force from the point of view of the particle in the center of your coordinate system.
If you think about it, this must be the case: the particle in the center doesn't move at all. It has zero acceleration, so it must have zero net force, from that perspective. This statement is unchanged no matter which particle you choose to be at the center of your coordinate system.
The statement does not hold, however, for particles away from the center of the coordinate system, as you can see by examining the force of the atoms on the surface of a hypothetical sphere which is centered at the origin in that particular coordinate system. Those particles will have a net force.
If it seems odd that those particles would have a net force in one frame and not another, bear in mind that these reference frames are accelerated relative to one another, so of course the forces are going to be different as well.
  • #43
Chalnoth, I can imagine both a) and b) hold, but still am not sure about b).
Bill_k, Marcus and Mordred reject b), so no consensus. Anyone to comment?
