sevenperforce
- 82
- 16
Certainly. I was speaking qualitatively for the sake of brevity up until now, but the math is definitely where things get interesting.PeterDonis said:I don't know where you are getting this from. If you have a peer-reviewed paper that shows how this result is derived, or if you can give the derivation yourself, then please show your work. Otherwise, as above, you're just handwaving.sevenperforce said:If Hawking's predictions are correct all the way down to the Planck scale, then there would have to be a minimum-mass black hole not based on the Planck mass, but based on the point at which the Hawking radiation particles would have an energy equal to half the mass-energy of the black hole.
Extrapolating Hawking's predictions all the way down to the Planck scale for very, very small black holes will run you into nonsense pretty fast because the power output goes to infinity as the mass goes to zero. It may be, of course, that Hawking's equations simply no longer hold well before this point is reached. But if they do hold true all the way down, then the very last step of black hole evaporation must necessarily involve the entire remaining mass-energy of the black hole being released at once. However, Hawking's model requires that the radiation match a blackbody curve corresponding to the black hole temperature. Since the wavelength is also going to zero as the mass goes to zero, the particle energy is necessarily going to go to infinity, and so the minimum possible mass will correspond to the point where the peak wavelength of the Hawking radiation corresponds to a particle energy Ep = hc/λ(TH) matching the total mass-energy of the black hole E = Mc2:
hc/λ(TH) = Mc2 or M = h/λc(TH)
For the sake of momentum conservation, however, this has to be adjusted; you actually need two particles, each with half the mass-energy of the black hole. I did the math in the other thread here.
