Gravitational constant in english units
In summary, despite the historical reasons for the usage of English units, there are much better units available that are more accurate and easier to follow. The problem is that students who are taking a fluid mechanics class are not used to using these better units and are struggling to understand the calculations.
gfd43tg
50
Hello,
I am taking a fluid mechanics class right now, so I deal a lot with water flowing through a pipe, and equations involving the density of the fluid.
The problem is, that since I'm an engineering major, we use way too many english units. There is something inherent about non-SI units I believe that makes my calculations hard to follow, especially when dealing with the density of a fluid.
The book will randomly divide the density by the gravitational constant, and I am having trouble understanding why the gravitational constant is omitted sometimes and not omitted other times when doing calculations, and how I can keep it straight when to include or not include it.
For example, the equation p = ρgh. You end up dividing out the constant g.
Also, a kg m/s^2 is one Newton. Is a lb_m ft/s^2 a lb_f??
Maylis said:
Hello,
No. The conversion factor is [itex]\frac{1}{32.2}\frac{lb_fsec^2}{lb_mft}[/itex].
why is it then that the conversion in SI units is not 1 N s^2/9.8 kg m??
In "English units" (which are no longer used in England in science and engineering, so they really ought to be called "stupid American units" IMHO) the weight of 1 pound mass, on the surface of the earth, is 1 pound force.
In SI units, the weight of one kilogram is 9.8 Newtons.
Of course the weight of one kilogram would be 1 kilogram-force, except that nobody uses "kilogram-force" as a scientific unit.
(A force of 1 Newton is approximately the weight of one apple, which is a nice coincidence.)
Likes 1 person
Then what the heck is the difference between a slug and a pound mass?? Two english units for the measurement of mass
A slug is 32.2 lbm. Slug is really the mass unit you want to use if you want F = ma to give you the force in lbf. One lbf is the force you need to exert on a mass of 1slug to give it an acceleration of 1 ft/sec2. If you exert a force of 1 lbf on a 1 lbm, its acceleration will be 32.2 ft/sec^2.
The same influences that drive various American engineers to use the pound mass as the unit for mass and the pound force as the unit of force drive their metric counterparts to use the kilogram-force. For example, space agencies in metric countries ofttimes expresses rocket thrust in units of kilogram-force (aka kilopond) rather than in Newtons.
You wouldn't find "stupid American units" to be quite so stupid if all you had was a simple two-pan balance for dividing things...
Are you claiming that a simple two-pan balance works differently depending on the unit system you use to model it?
O well, I guess idea that the same laws of physics apply everywhere in the universe was wrong - they are different in the USA.
No, I'm saying one can divide a pound of, for instance water, into 16 separate ounces of water with primitive technology. There is no easy way to divide a litre of water into 10 decilitres of water using a two-pan balance.
The point is, such things as "stupid units" had a reason for existing.
Regardless, historical reasons are no justification for continuing on with the usage of inferior units when we have much better options available.
Sure, there's going to be a big hurdle at the beginning, but it's worth it long term.
I have never seen a mathematical or computer model from a European company that used anything other than the Newton as a force unit. What they put in their press releases (and/or sales presentations when selling to the USA) is a different matter, or course.
The thing that really ****** me off about US units is not so much the conversion factor, as the fact that US engineers seem incapable of deciding what value to actually use. Getting three different versions of the same model of the same object, from the same US company, with three different conversion factors, is "normal" - even after the formal contract has specified what units systems are to be used, including the agreed value.
Yeah. I suppose that explains why there were 14 pounds in a stone, and 20 hundredweight in a ton :devil:
I guess it's just by chance that a well informed USA treasury decided to use 100 Cents in a dollar and not 12 $hillings or something. The justification for using 16oz in a pound sounds more like numerology than Maths, Engineering of Science.
I doubt the people who invented and used such measures a few thousand years ago would agree with you.
I'm not claiming the funny old units are better or anything, but they were perfectly practical and useful in the entirely different ancient world. This is how we get folks thinking that space aliens built the Egyptian pyramids... because they can't possibly believe anyone who used something so ridiculous as numbers based on twelves or sixties could have achieved anything.
Using a number base that has many factors is brilliant for doing mental arithmetic. Also, there are good reasons for using units that relate to body dimensions. Technology changes things.
That's what we probably all agree with.
And it is exactly a reason why continuing to use them today is so nonsensical.
It's still nice to know that eggs, at 31/2d each, are 3/6 a dozen. (Look it up.)
Chestermiller said:
... If you exert a force of 1 lbf on a 1 lbm, its acceleration will be 32.2 ft/sec^2.
To the OP (and anyone else confused by g and gc, where the factors of 32 go) in fluid mechanics, read the above sentence over & over again until it sinks in.
As far as changing from inch to metric/SI goes, I think it would have happened a long time ago if the Earth's circumference had worked out to 2.56 cm per inch rather than the 2.54 factor we have. At 2.56, you could cut "metric" threads on an inch screw lathe using the normal set of change gears; with the 2.54 factor you need a 127 tooth gear - harder to make and if you do make one, it is too big in diameter to fit in the lathe gearbox. Thousands of factories and shops with probably millions of expensive lathes and mills = lots of resistance to changing standards. With modern CNC stuff it doesn't matter anymore, but for essentially all of the 20th century it did.
Likes 1 person
Related to Gravitational constant in english units
1. What is the value of the gravitational constant in English units?
The value of the gravitational constant in English units is approximately 6.67 x 10^-11 m^3 kg^-1 s^-2.
2. How is the gravitational constant calculated in English units?
The gravitational constant in English units is calculated by dividing the force of gravity between two masses by the product of their masses and the square of the distance between them.
3. Why is the gravitational constant important in physics?
The gravitational constant is important in physics because it helps to describe the strength of the gravitational force between two objects. It is a fundamental constant in the law of universal gravitation, which explains the motion of objects in the universe.
4. Does the value of the gravitational constant change in different systems of units?
Yes, the value of the gravitational constant can change depending on the system of units used. For example, in the metric system, the value is different than in English units. However, the relationship between the gravitational constant and other fundamental constants remains the same in all systems of units.
5. How was the gravitational constant first measured?
The gravitational constant was first measured by English scientist Henry Cavendish in the late 18th century using a torsion balance. He measured the force of gravity between two lead spheres and used this information to calculate the value of the gravitational constant in English units.
  • Other Physics Topics
