Gravitational entropy in the early universe
In summary, Penrose wrote in the Road to Reality that gravitational clumping increases the entropy of the universe. The early universe was very low in entropy because it was very smooth, with very little clumping.
Khashishi
492
So, is it accurate to say that the early universe was high in entropy except for the gravitational contribution? Almost like the universe was allowed to equilibrate without gravity and then gravity was suddenly turned on? If gravity was turned off for the beginning of the universe, would this explain the low entropy of the initial universe?
Space news on Phys.org
No, because there isn't a separate gravitational contribution. Penrose was not saying that there are two kinds of entropy, gravitational and non-gravitational, and you just add them up. He was saying that entropy in the presence of gravity works fundamentally differently from entropy in the absence of gravity. In the absence of gravity, a clumped state has lower entropy than a smooth state; but in the presence of gravity, it's the other way around.
No, because you can't "turn gravity off". More precisely, turning gravity off would be equivalent to spacetime being flat, and we know the spacetime of the early universe was not flat. In fact, it was more curved then than it is now.
How do we know the early universe was not flat?
Because it was expanding rapidly, much more rapidly than now. A higher rate of expansion means a greater spacetime curvature. (More precisely, it was expanding much more rapidly, but there was also a higher rate of change of the expansion rate. Both of those things are manifestations of higher spacetime curvature.)
From the standpoint of the Einstein Field Equation, the reason for the greater curvature is that the universe was a lot denser then than it is now, so the source term on the RHS of the EFE was much larger, hence the curvature on the LHS was also much larger. (Also, the early universe was radiation-dominated rather than matter-dominated, so pressure was a significant source of gravity, increasing the RHS of the EFE still further.)
But what if something is missing from the model? The reason I say that is because as far as I know, current measurements show that the universe is flat. I know that inflation explains why the universe is almost flat, but another explanation is that maybe the universe really is perfectly flat. Then it must have always been flat. Maybe flatness was part of the initial conditions of the universe.
I know you can't answer a question like "what if the model is wrong", but you can address how well grounded the model really is. I know dark energy is supposed to be negligible in the early universe, but as far as I know, dark energy is just a fudge factor to make Einstein's field equations predict an accelerating universe.
A follow up question. Was the curvature in the early universe positive or negative?
Current measurements show that the universe is spatially flat. We are talking about spacetime curvature, not space curvature. The only way to have a flat spacetime is to have zero matter or energy anywhere. So I could have answered your earlier question by saying that we know the early universe was curved because we know there was matter and energy present. (And as I said in a previous post, because the density of matter/energy was much larger in the early universe, the curvature was much greater as well.)
It has always been positive--more precisely, the Ricci scalar has always been positive.
This is incorrect in two ways. First, a cosmological constant is not a "fudge factor" added to the EFE; it belongs there. This is easiest to see if you derive the EFE from a Lagrangian; the most general Lagrangian that satisfies the desired criteria (no more than second derivatives of the metric) is not ##R \sqrt{-g}## but ##\left( R + \Lambda \right) \sqrt{-g}##.
Second, a cosmological constant is not the only way to get accelerating expansion. Any equation of state with ##w < - 1/3## (i.e., with ##p < - (1/3) \rho## ) will give accelerating expansion. A scalar field can have such an equation of state. So our current model, which has ##w = -1## (i.e., a cosmological constant as opposed to some other kind of field producing accelerating expansion), is not the only possible model that gives accelerating expansion; it is our best current model because ##w = -1## best matches the data.
Related to Gravitational entropy in the early universe
1. What is gravitational entropy in the early universe?
Gravitational entropy in the early universe refers to the measure of disorder or randomness in the distribution of matter and energy in the universe during its early stages of expansion.
2. How is gravitational entropy related to the Big Bang Theory?
According to the Big Bang Theory, the universe began as a hot, dense and highly ordered state. As the universe expanded, the distribution of matter and energy became more disordered, leading to an increase in gravitational entropy.
3. How does gravitational entropy affect the evolution of the universe?
The increase in gravitational entropy has a direct impact on the evolution of the universe. As the universe expands, the increase in entropy leads to a decrease in the available energy, making it less likely for new structures and galaxies to form.
4. Can gravitational entropy be reversed?
As of now, it is not known if gravitational entropy can be reversed. However, some theories suggest that the universe may undergo a "big crunch", where the expansion of the universe is reversed, and gravitational entropy decreases.
5. How is gravitational entropy measured?
Gravitational entropy is measured using various mathematical models and equations, such as the Boltzmann entropy formula and the holographic principle. These models take into account the distribution of matter and energy in the universe and provide a measure of the overall level of gravitational entropy.
