Gravitational Field From Ring Mass
In summary, the formula for the gravitational field for a point mass on the axis of a ring is derived in introductory physics textbooks as g_{x} = -\frac{Gmx}{(x^2 + a^2)^{1.5} }, where m is the total mass of the ring, x is the distance from the point mass to the center of the ring, and a is the radius of the ring. However, for a more general treatment of the ring when the point mass is not on the axis, integration is required and symmetry is needed for the math to be simplified. This approach can also be applied to other systems.
edgepflow
688
Most introductory physics textbooks derive the following formula for the gravitational field for a point mass on the on the axis of the ring:
[itex]g_{x}[/itex] = -[itex]\frac{Gmx}{(x^2 + a^2)^{1.5} } [/itex]
where,
m = total mass of ring
x = distance from point mass to ring center
a = radius of ring
Is there a more general treatment for this ring when the point mass is not on the axis?
yes, and for any other system as well. To solve it for an axis you need to have symmetry like the ring, or the math won't be pretty. Basically integrate dF (dF = GM/r^2 dm , dm=ρdV) over the volume to find F(r)
FAQ: Gravitational Field From Ring Mass
What is a gravitational field from ring mass?
A gravitational field from ring mass is a region in space where an object with mass experiences a force due to the gravitational pull of another object with mass, in this case a ring-shaped object.
How is the strength of a gravitational field from ring mass determined?
The strength of a gravitational field from ring mass is determined by the mass of the ring and the distance from the center of the ring to the point where the gravitational force is being measured.
What is the formula for calculating the gravitational field from ring mass?
The formula for calculating the gravitational field from ring mass is G * M / r^2, where G is the universal gravitational constant, M is the mass of the ring, and r is the distance from the center of the ring to the point where the gravitational force is being measured.
How does the shape of a ring affect its gravitational field?
The shape of a ring does not affect its gravitational field. As long as the mass and distance remain the same, the strength of the gravitational field will also remain the same.
Can the direction of a gravitational field from ring mass change?
No, the direction of a gravitational field from ring mass remains constant. The direction of the gravitational force will always be towards the center of the ring, regardless of the position or orientation of the object experiencing the force.
