Gravitational Field Paradox Explanation?
In summary, the conversation discusses the concept of infinite nature in electric and gravitational fields, and how it can lead to potential paradoxes. The conversation also delves into the idea of instantaneous transmission of the gravitational field and how it relates to the speed of light. Ultimately, the conclusion is that while these fields may appear to be instantaneous, they are actually connected to conservation laws and do not violate the principles of relativity.
Theheretic
31
Gravitational Field Paradox Explanation??
Hi everyone. If electric and gravitational field has an infinite nature-meaning that the effect one charged particle has on another charged particle always remains even though it diminishes over distances but can never reach absolute 0-then how is this possible without being some sort of paradox?
It seems to me similar to a layman's version of quantum entanglement concept.
What I mean is, if you think of a gravitational effect an object has on another object via 'gravitational field'. For instance let's say the Earth exerts a certain gravitational field on a person floating in space a few thousand miles above the earth. Then let's say you move that person billions of light years away to the very edge of the known universe. The Earth is said to be still exerting a gravitational field on that person just a very miniscule and mostly negligible amount. Yet to my understanding it is STILL an amount and can never be 0.
So my main question is this: Since the Earth is always exerting this gravitational field onto this person instantaneously, then isn't this a "faster than light" sort of transmission? For instance let's say that right now the Earth is exerting this gravitational field on this person/object who is 15 billion light years away. And right this instant the Earth was blown up to smithereens and completely annihilated. An equation would show presumably that the Earth no longer exerts any field on this person 15 billion light years away instantaneously. The field of exertion presumably does not travel at light speed so I don't think it is right to say that it will now take 15 billion light years for the gravitational effect to wear off.
I know this may be getting into the general area of the higgs-boson but if we wanted to simplify away from that then we can use the electromagnetic field or etc.
So how is it that the "field" that is exerting the gravitational or electromagnetic pull on the person from 15 billion light years away, "INSTANTLY" knows that the Earth no longer exists and thus no longer exerts that pull?
Just to phrase this question into a slightly simpler thought experiment in case anyone is confused about my question (since I'm a completely un-educated noob in this regard so I realize some of the things I may be saying or describing are asinine).
But let's take a hypothetical vacuum that is as wide as our universe but has no other matter in it that is able to exert any sort of electromagnetic or gravitational influence. i.e. not a single atom of matter exists OTHER than 2 objects that are separated by 15 billion light years. Since these objects are the ONLY 2 things in existence, if my fundamental understanding of these things serves, then the 2 objects will begin floating towards each other albeit at perhaps an exponentially and microscopically slow rate. But they will be exerting a gravitational pull on each other even from 15 billion light years away since as I understand it, gravitational "field" has no limit and can never be 0.
So let's just say they're slowly creeping towards each other from 15 billion light years away and one of those objects suddenly disappears or is somehow annihilated (for the sake of this conversation let's pretend it's able to break law of conservation of matter and be annihilated). Then how does object #2 that is 15 billion light years away instantly stop pulling towards the gravitational field of object #1? This would require a superluminal instantaneous "communication" of the gravitational field from 15 billion light years away. Whether it's a higgs boson or whatever is responsible for gravity how can it immediately inform the 2nd object that is 15 billion light years away to stop being exerted by the force of the 1st object?
I seemed to have answered my own question through subsequent research.
http://en.wikipedia.org/wiki/Speed_of_gravityGravitational "waves" travel at the speed of light and thus are not "instantaneous".How about electric charge fields? When a particle has a positive charge and attracts or repels another particle of a negative charge? What constitutes this? Electromagnetic fields which also travel at light speed?
Since light is nothing more than wobbling electro-magnetic fields you can probably figure this one out yourself.
Not the same issue. Both electromagnetic and gravitational waves travel at a finite speed c. But the Coulomb field for a charge, and the Newtonian field for a mass, don't have anything to do with waves.
These fields do appear to be instantaneous, and in some formulations they are indeed treated this way. But the reason they can get away with it without violating relativity is because of the conservation laws. A charge cannot just suddenly appear, nor can a mass. Thanks to charge conservation, the charge has "always" been there (or somewhere!), and thus the Coulomb field surrounding it has always been there too. Likewise for gravity, the source of the gravitational field is energy (technically, the stress-energy tensor), and energy is locally conserved - it cannot suddenly appear or vanish.
This is exactly what can NOT happen.
That's a bit misleading. It's more that the field (there's actually only one, shared by all particles) has existed since the beginning of the universe.
What we are talking about here is changes in that field caused by the movement of charges. Those changes propagate at c.
Since charge cannot spontaneously appear out of nothing, the field cannot change discontinuously. If such a thing were to happen somehow, the field might propagate at some other speed - maybe infinite - who knows? Maybe that has something to do with non-locality.
"These fields do appear to be instantaneous"
Not a bit! Some quantizations of electromagnetism involve an instantaneous Coulomb interaction in the literal sense.
Some do and some don't. Radiation does. But both electromagnetism and gravity allow "nonradiative motions". For example the lowest order of gravitational radiation involves the third time derivative of the source's quadrupole moment. If the source moves in such a way that it has no quadrupole moment, it won't radiate. Even if it has a quadrupole moment, it won't radiate if the third derivative vanishes. The Newtonian field certainly changes, but no radiation is produced.
Hypothesizing something happens that cannot happen in the first place naturally leads to paradoxes.
When I'm trying to explain something in layman's terms, I like to keep it simple.
There are always sophisticated argument at the fringes of exploration that can be invoked as 'exceptions' to established rules.
I consider it misleading to bring them up unless the OP has the tools to fully understand the subtlety.
So does this mean, basically, that demanding relativity holds essentially forces the conservation laws to hold, and also that if there were such a thing as a perpetual motion machine, we could also go back and kill our grandfathers before our parents were born?
That's a good idea. Also keep it correct.
However, I thought the thing was that instantaneous "force" was OK, but instantaneous "transfer of information" was not. The latter is limited by c.
Related to Gravitational Field Paradox Explanation?
1. What is the gravitational field paradox?
The gravitational field paradox refers to the apparent contradiction between Newton's theory of gravity and Einstein's theory of general relativity. According to Newton, the force of gravity is instantaneous and acts at a distance, while Einstein's theory suggests that gravity is the curvature of spacetime caused by massive objects.
2. How does this paradox arise?
This paradox arises because Newton's theory of gravity assumes that gravity acts instantaneously, meaning that an object would immediately feel the gravitational pull of another object regardless of its distance. However, according to Einstein's theory, gravity is a curvature of spacetime and takes time to propagate, meaning that the force of gravity would not act instantaneously over large distances.
3. What evidence supports Einstein's theory over Newton's?
One of the strongest pieces of evidence for Einstein's theory of general relativity is the observed bending of light near massive objects such as stars and galaxies. This effect was predicted by Einstein's theory and has been confirmed through observations and experiments.
4. Can the paradox be resolved?
There are several proposed solutions to the gravitational field paradox, including modifications to Newton's theory of gravity or incorporating the concept of quantum gravity. However, a complete resolution is still a topic of ongoing research and discussion in the scientific community.
5. How does understanding the gravitational field paradox impact our understanding of the universe?
The gravitational field paradox challenges our current understanding of gravity and the laws of physics. By exploring potential solutions to this paradox, scientists hope to gain a deeper understanding of the fundamental nature of the universe and potentially uncover new discoveries about the nature of gravity and spacetime.
  • Astronomy and Astrophysics
