Gravitational force and density.
In summary, a spherically symmetric body affects external objects gravitationally as though all of its mass were concentrated at a point at its center. This is due to Gauss's law, which applies to both electric and gravitational fields. This means that the distribution of mass or charge inside the sphere does not matter as long as the total enclosed mass or charge is the same. This can be mathematically proven using integral calculus.
PatPwnt
83
A spherically symmetric body affects external objects gravitationally as though all of its mass were concentrated at a point at its center. Is this true and can someone explain this? For example, wouldn't Earth as a black hole attract the moon with slightly more force because it's volume is condensed? Doesn't the outer portion of the Earth produce a gravitational field line not parallel to the line between the centers of the moon and Earth thus canceling the the perpendicular components of the gravitation forces?
Yes this is true. The reason comes from Gauss's law. The electric form (as I can't recall the gravitational form off the top of my head) is (this will all be essentially the same for the gravitational force, as they both follow 1/r^2 laws)
[tex]\oint_S{\vec{E}\cdot d \vec{S}} = \frac{Q_{enc}}{\epsilon_0}[/tex]
Therefore, if we have a (gaussian) surface in which, the field is parallel to the surface normal, we can write:
[tex]\vec{E} = \frac{Q_{enc}}{A\epsilon_0}[/tex].
Such a surface is a sphere, since the electric field is radially outward. If we are outside the sphere, say a distance R from the centre, the field will always be
[tex]\vec{E} = \frac{Q_{enc}}{4 \pi R^2\epsilon_0}[/tex]
It does not matter whether the charge is uniformly distributed throughout the volume of a sphere, over the surface of a sphere, or is a point charge at the origin, as long as the enclosed charge is the same. (If we are inside a sphere, this does not work, as the enclosed charge varies with R)
As long as you are outside the event horizon of a non-rotating BH, you can't say whether it's a BH or just a spherically symmetric distribution of mass. The force is different from the Newtonian case, of course.
Actually, it does not matter in whatever way the charge or mass is distributed inside as long as only the monopole term survives outside the boundary of the sphere.
Some mathematics is necessary, which proves that the field of an infinitesimally thin shell of uniform mass density outside the shell is the same as that of a point mass of equal mass situated at the centre. For a spherically symmetric distribution, a sphere can be mentally broken up into infinite such shells and the field of the whole sphere outside then will be like that of a point mass equal to the mass of the sphere sitting at the centre.
(En passant, Newton had to invent Integral Calculus to prove this.)
here's how to recall the gravitational form. first recall the two inverse-square forms:
[tex] F = k \frac{q Q}{r^2} = \frac{1}{4 \pi \epsilon_0} \frac{q Q}{r^2} [/tex]
[tex] E = \frac{F}{q} = \frac{1}{\epsilon_0} \frac{Q}{4 \pi r^2} [/tex]
[tex] F = G \frac{m M}{r^2} [/tex]
[tex] \frac{F}{m} = 4 \pi G \frac{M}{4 \pi r^2} [/tex]so you can replace symbols in equivalent roles.
Newton (or Leibnitz) did invent IC, but in his Principia he actually used an ingenious, but complicated, geometric method.
Yes, I have seen it. It's almost completely geometrical, and very difficult for us (or at least for me) to understand. His reason for doing so was for the benefit of his contemporaries, since they too wouldn't have understood the newly invented IC, which itself was written very cumbersomely.
Related to Gravitational force and density.
1. What is gravitational force?
Gravitational force is a fundamental force of nature that attracts any two objects with mass towards each other. It is responsible for keeping planets in orbit around the sun and objects on Earth from floating off into space.
2. How is gravitational force calculated?
Gravitational force is calculated using Newton's law of universal gravitation, which states that the force of attraction between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
3. What is the relationship between gravitational force and density?
The relationship between gravitational force and density is indirect. Gravitational force is directly proportional to mass, while density is the measure of an object's mass per unit volume. Therefore, objects with higher density will have a stronger gravitational force compared to objects with lower density.
4. How does gravitational force affect objects of different densities?
Objects with higher density will have a stronger gravitational force compared to objects with lower density. This means that objects with higher density will have a greater tendency to attract other objects towards them due to their stronger gravitational pull.
5. How does gravitational force vary on different planets?
The strength of gravitational force varies on different planets due to the difference in their masses and sizes. Planets with larger masses and sizes will have a stronger gravitational force compared to smaller planets. Additionally, the distance between the planet and an object also affects the strength of gravitational force experienced by that object.
