Gravitational force at the Earth's centre
In summary, the discussion explored whether an observer at Earth's center would feel zero gravity or a gravitational pull towards the surrounding mass. The shell theorem was suggested as a reference and it was argued that gravity cannot be felt as long as it is uniform. The concept of weightlessness was also discussed in relation to gravity. Ultimately, it was concluded that while the Earth's gravity would not be acting on an observer at its center, they would still be subject to the gravitational force of other matter and energy in the universe.
Grahame1
One of my students asked if the graviational force at the Earth's centre is zero. The question was thrown open to the other students and two possible answers were given: zero or infinite! One way of reasoning is to say that the graviational force sums to zero as (assuming uniformity of the Earth) for every force pulling one way is 'cancelled' by and equal and opposite force. But I then imagined modelling the pull of gravity by tension in a rope. Suppose you hold two ropes, one in each hand and the ropes pull in opposite directions with the same magnitude of force. It is true that I wouldn't accelerate as the forces 'cancel' (note the quotation marks), but I certainly wouldn't feel zero force! So the question is: would an observer at Earth's centre feel zero gravity, or would that observer feel the gravitational pull outwards (in all dirctions) towards the surrounding mass?
Zero gravity. Every particle of your body is pulled in both directions (every direction, in fact) and the forces cancel on every particle, so you feel nothing. That's not the same as having a rope tied to each arm.
The "shell theorem" is the thing to look up.
Google spherical shell theorem.
A flip answer is that you cannot "feel" gravity at all, as long as it is uniform. It pulls on all parts of your body equally. What you "feel" instead is the contact force of your feet on the floor or your butt in your chair and the various internal compression and tension forces that keep you standing upright on your feet or keep you from slumping out of your chair.
Edit to add: An astronaut in a spacecraft orbiting in low Earth orbit about 200 miles up is subject to a force of gravity that is about 90% as strong as on the Earth's surface. The astronaut feels weightless because nothing is pushing on him, not because there is no gravity.
0. Suppose you have non zero gravity, and at moment 0 you are at rest, by Newton's second law, you will have a non-zero acceleration, but which way? The globe is symmetrical, no direction is more privileged than others. Hence the gravity by Earth at Earth center should be 0.
Though the Earth's gravity would no longer be acting on you (since presumably you would already be at it's center of mass), you would still be subject to the gravitation force of other matter and energy in our solar system and beyond, given sufficient time for the space-time curvature (i.e., gravity) to reach you.
Related to Gravitational force at the Earth's centre
1. How is gravitational force calculated at the Earth's centre?
Gravitational force at the Earth's centre is calculated using the formula F = G * (m1 * m2)/r^2, where G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
2. What is the value of gravitational force at the Earth's centre?
The value of gravitational force at the Earth's centre is approximately 9.8 m/s^2. This is commonly known as the acceleration due to gravity.
3. How does the gravitational force at the Earth's centre affect objects?
The gravitational force at the Earth's centre causes objects to accelerate towards the centre of the Earth. This force is what keeps objects on the surface of the Earth and gives them weight.
4. Does the gravitational force at the Earth's centre change with depth?
Yes, the gravitational force at the Earth's centre changes with depth. As an object moves closer to the centre of the Earth, the force of gravity becomes stronger, and as it moves away, the force becomes weaker. This is due to the change in distance between the object and the Earth's centre.
5. How does the gravitational force at the Earth's centre compare to other planets?
The gravitational force at the Earth's centre is relatively strong compared to other planets in our solar system. However, it is not the strongest. For example, the gravitational force at the centre of Jupiter is much stronger than at the Earth's centre due to its larger mass.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanics
