Gravitational force between two objects?
In summary: Assuming the reduced mass is much smaller than the total mass of the two bodies, the one-body problem will be a new problem that has a solution.In summary, the two-body problem orbits are elliptical (unless they crash into each other). If you want to solve the trajectory motion, you can reduce the two-body problem to a one-body problem, using the concept of reduced mass. Assuming the reduced mass is much smaller than the total mass of the two bodies, the one-body problem will be a new problem that has a solution.
tummbacoco
I know that the force of gravity is (ma)=GMm/r^2 or a=GM/r^2
This makes sense and If I were to drop a bowling ball down to Earth I'd expect it to fall with 9.8m/s^2. However I can calculate that the bowling ball has its own gravity using the formula noted above. My question is what will be the true acceleration of these 2 objects towards each other?
Perhaps a better example is the Earth and say Jupiter. Would these 2 planets go towards each other at a rate of 25m/s^2(gravity of Jupiter), or perhaps they would go towards each other with 35m/s^2(Gravity of Jupiter+Earth) because the they are both pulling each other in right?
So this question seems so simple that any info I've found on it, neglects an explanation. Anyways, thanks!
You know the force of the ball on the Earth and you know the Earth's mass. What is the acceleration of the Earth towards the ball? So they both move towards each other.
So you are saying that adding up their accelerations would be the true acceleration of gravity? By that logic, does that mean that an object of higher mass would indeed fall faster than a lower mass object due to the fact that the higher mass object pulls the Earth towards it more, thus shortening the time it takes for it to reach the ground?
And this wouldn't even violate Newtons law because the Earth is pulling on both objects at the same acceleration, it's just the more mass the more that the Earth gets pulled towards the object?
There is an important subtlety here. You're talking about the acceleration of the object... but is that the acceleration observed by someone standing on the surface and considering himself to be at rest? Or is it the acceleration observed by some distant observer watching the Earth and the falling object being pulled towards one another? These will not be the same, and there's no particular reason to call either one "the true acceleration of gravity".
If you drop an object on Earth, the gravitational force of the Earth on the object is the same as the gravitational force of the object on the Earth. There is no violation of Newton's law (until you get into extremes requiring general relativity).
The two-body problem orbits are elliptical (unless they crash into each other). If you want to solve the trajectory motion, you can reduce the two-body problem to a one-body problem, using the concept of reduced mass.
Related to Gravitational force between two objects?
1. What is the formula for calculating the gravitational force between two objects?
The formula for calculating the gravitational force between two objects is F = G(m1m2/r^2), where F is the force, G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
2. How does the distance between two objects affect the gravitational force between them?
The gravitational force between two objects is inversely proportional to the square of the distance between them. This means that as the distance increases, the force decreases.
3. Does the mass of the objects affect the strength of the gravitational force between them?
Yes, the mass of the objects does affect the strength of the gravitational force. The greater the mass of the objects, the greater the force between them.
4. What is the unit of measurement for gravitational force?
The unit of measurement for gravitational force is Newtons (N). This is the same unit used to measure other types of forces.
5. Can the direction of gravitational force change between two objects?
No, the direction of gravitational force between two objects is always towards each other. This is known as an attractive force, and it is always directed along the line connecting the two objects.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanics
  • Classical Physics
