Gravitational force of the Earth and Moon
In summary: Earth's gravitational force is that all objects, regardless of their mass, will fall towards the Earth at the same rate of acceleration. This is due to the relationship between force and acceleration, which is expressed in the equation $$ma=mg$$. On the moon, where the gravitational force is weaker, objects will fall towards the moon at a slower rate of acceleration. This explains why objects of different masses do not appear to be affected by gravity in the same way on the Earth and the moon.
akhila_k
A person of mass 60kg will weigh around 100N on the moon. This is roughly equivalent to the gravitational force on a 10kg object on Earth.
Even if the forces acting on both are about the same, we don't see 10kg objects floating around on Earth whereas a man weighing 60kg can easily float on the moon. Why?
Imagine an evacuated room on earth, so no air in it. Now from the top of the room you drop a bowling ball and and a feather at the same moment. Which of the two objects does reach the bottom first?
akhila_k said:
Even if the forces acting on both are about the same, ...
How is force related to acceleration?
Both reach at the same time. Ok, now I get it. Irrespective of mass, the objects on Earth would speeding toward it at a constant acceleration. And on moon this value is just 1/6th of the Earth's. Thank You.
Now then, what is the effect of Earth's gravitational force? Since the force on objects of different mass are different, something about them should be different, isn't that so?
So the mass/weight doesn't seem to make a difference. That's why no object is "floating" on Earth and all objects are "floating" on the moon. Now the question remains, why is that. The reason is that not only the graviational force is proportional to the mass of the object, but also its inertia. Mathematically you can express that like this:
$$ma=mg$$
, where ##m## is the mass of the object, ##g## the gravitational acceleration and ##a## the acceleration. The equation just states that the graviational (weight) force acting on the object equals the resistance of the object to change its state of movement (inertia). Independent on the mass of a certain object, the acceleration only depends on the acting graviation - therefore the higher gravitation of the Earth increases the speed of the object faster than the weaker gravitation of the moon.
$$ma=mg$$
That was much helpful. Thank You.
On Earth, objects of different masses do experience different gravitational force. But the effect we can observe, i.e. the acceleration is the same. So isn't there anyway we would 'feel the difference'?
Yes, and it is proportional to their mass.
Yes, in absence of any other force (e.g. drag due to air).
I'm not sure if I understand what you mean. One can feel the difference between varying accelerations, I'm pretty sure you could feel the difference between the acceleration you are experiencing on the Earth and on the moon respectively. Also the human body cannot stand too high accelerations, and one has to train to withstand them, like astronauts or (jet) pilots have to.
Likes akhila_k
What I meant was, two bodies falling freely on Earth wouldn't know that they've different masses and hence different forces acting on them, because they're experiencing the same acceleration. Isn't that so?
That's right, they couldn't know just by observing each other, since the evolution of their velocities is identical. Still though, the heavier object experiences a larger force.
Ok. Now I get it. Thank you so much.
If the objects are in free fall, the acceleration that they feel is zero. They will feel as if they are weightless.
There is a term, "proper acceleration" which refers to the acceleration you can feel. The acceleration that you can see (for instance by watching the ground come up and smack you in the face) is called "coordinate acceleration".
If you are free falling on Earth, you experience 0 gees of proper acceleration while having 1 gee of downward coordinate acceleration relative to the Earth's surface.
If you are standing still on Earth, you experience 1 gee of upward proper acceleration while having 0 gees of coordinate acceleration relative to the Earth's surface. Your proper acceleration is the result of the floor pushing upward on your shoes.
If you are free falling on the moon, you experience 0 gees of proper acceleration while having 1/6 gee of downward coordinate acceleration relative to the moon's surface.
If you are standing still on the moon, you experience 1/6 gee of upward proper acceleration while having 0 gees of coordinate acceleration relative to the moon's surface. Your proper acceleration is the result of the moon's surface pushing upward on your boots.
Likes akhila_k and m4r35n357
It has already explained that this is not a matter of mass but of gravitational acceleration only. However, you can fake a similar behaviour on Earth. If you want a car look like driving on the Moon, than make a movie of it driving with f = sqrt(gEarth/gMoon) the speed and play it in slow motion.
It's typical of human beings to take for granted the way people walk on the Moon - it was 'obvious' in retrospect. But it was certainly not predicted by Hollywood until people actually had been seen walking. There was a Film (Countdown 1967) that was released only just before the Apollo project and James Caan was shown, walking around quite 'normally', as on Earth. The credibility of that film was shot as soon as Armstrong and pals were seen doing it properly. A shame because the basic story was very good - at least as good as Capricorn One, in which, in the plot, no one actually walked on the Moon. Both story lines were basically Political. (You should watch both of them.)
That in itself is a great argument against the Moon Landing Conspiracy because Armstrong and Aldrin would have been walking as if on Earth if they weren't actually there at the time
Thank you. This is new information for me.
Related to Gravitational force of the Earth and Moon
1. What is the gravitational force of the Earth and Moon?
The gravitational force of the Earth and Moon is the attractive force between the two bodies due to their masses. It is responsible for keeping the Moon in orbit around the Earth.
2. How does the gravitational force of the Earth and Moon affect tides?
The gravitational force of the Earth and Moon is the primary factor in creating tides on Earth. The Moon's gravitational pull causes the ocean on the side of the Earth closest to the Moon to bulge, creating high tide. The ocean on the opposite side of the Earth also experiences high tide due to the centrifugal force of the Earth's rotation.
3. How does the distance between the Earth and Moon affect the gravitational force?
The gravitational force between two objects is inversely proportional to the square of the distance between them. This means that as the distance between the Earth and Moon increases, the gravitational force decreases. However, the effect of this distance on the tides is minimal due to the Moon's relatively close proximity to Earth.
4. How does the gravitational force of the Earth and Moon compare to other forces?
The gravitational force between the Earth and Moon is relatively weak compared to other forces, such as the electromagnetic force and the strong and weak nuclear forces. However, it is still a significant force that plays a crucial role in the dynamics of our solar system.
5. Can the gravitational force of the Earth and Moon change over time?
Yes, the gravitational force between the Earth and Moon can change over time. This is due to the fact that the Moon's orbit around the Earth is not perfectly circular, and its distance from the Earth varies slightly. Additionally, the Earth's rotation slows down over time, affecting the strength of the gravitational force between the two bodies.
  • Other Physics Topics
  • Mechanics
14K
