Gravitational Force: Exploring Its Effects on Tides
In summary, the conversation discusses the concept of force on a mass point outside of a homogeneous sphere and whether the reaction force is applied to the center of the sphere. It is mentioned that this is not entirely true, as the attraction is greater for parts of the sphere closer to the point mass. The conversation also delves into the topic of tides and where to find more information on this subject.
Frank66
Hi,
it is well know that the force on a mass point outside to an homogeneous sphere is as the whole sphere's mass is concentred on its centre.
It seems that the reaction of this force (the total force of the point on the shepre) is applied on the centre of the sphere but, is it true?
If this is it true why tides?
Do you know a book where this is demonstrated?
thank you and excuse my english
Frank66 said:
Hi,
No it isn't true. The attraction is greater for parts of the sphere that are closer to the point mass.
if the force of the moon was only applied to the center of the earth, and not to the oceans as well, you'd have MUCH bigger tides.
thank you,
Have you reference? Where can I found the calculus?
For a rigid body, it is as if the force were applied to the center of gravity (which is why it is called the center of gravity!) but for a body which can be thought of as made of independent particles, the force acts on the individual particles. We can (roughly) think of the Earth as rigid body but not water. That's why "tidal" effects on the Earth itself are small compared with ocean tides.
Related to Gravitational Force: Exploring Its Effects on Tides
1. What is gravitational force?
Gravitational force is a natural phenomenon that causes objects with mass to attract each other. It is a fundamental force of nature that plays a crucial role in the formation and behavior of celestial bodies, such as planets, stars, and galaxies.
2. How does gravitational force affect tides?
Gravitational force is the primary driving force behind ocean tides. The gravitational pull of the Moon and the Sun on the Earth's oceans causes them to bulge, creating high tides. As the Earth rotates, the bulges move, resulting in low tides. The shape of the coastline and the depth of the ocean also influence the height and timing of tides.
3. What is the difference between spring tides and neap tides?
Spring tides occur when the Sun, Moon, and Earth are aligned, creating the strongest gravitational pull. This results in higher high tides and lower low tides. Neap tides, on the other hand, occur when the Sun and Moon are at a right angle to each other, creating weaker gravitational pull. This leads to lower high tides and higher low tides.
4. How does the distance between the Earth and the Moon affect tides?
The gravitational force between two objects decreases as the distance between them increases. Therefore, the closer the Moon is to the Earth, the stronger its gravitational pull, resulting in higher tides. When the Moon is at its closest point to the Earth (perigee), we experience higher tides, and when it is at its farthest point (apogee), we experience lower tides.
5. Can gravitational force affect tides on other planets?
Yes, gravitational force affects tides on other planets just like it does on Earth. However, the strength and timing of tides may vary depending on the size, mass, and distance of the planet from its moon(s) or the parent star. For example, Jupiter's moon Io experiences intense tidal forces, resulting in frequent volcanic activity, while Pluto's moon Charon is tidally locked, meaning the same side always faces Pluto.
  • Classical Physics
  • Other Physics Topics
