Gravitational Instability and accelerated explanation of Universe?
  • A
  • Thread starter say_cheese
  • Tags
    Expansion
say_cheese
41
TL;DR Summary
The time constant of instability corresponding to the Hubble derived mass density is 10^11 years (without a Cosmological Constant). Why is this not an explanation for the observed acceleration of the expansion of the universe?
Ref: Principles of Physical Cosmology by P.J.E. Peoples, Princeton Univ. Press
This question is likely fully answered somewhere, but I cant find it.
Hubble obtained (1926) the mean mass density of the Universe as 10^-31 g/c.c. The gravitational stability equation gives (McCrea, Milne (1934)) with no dark energy cosmological constant,
equation
later derivation without division by 3.
The resulting exponential time constant for the Gravitational Instability from this equation and the Hubble density is 10^11 years, much longer than the current age of the Universe.
The instability can result in increasing expansion, if the density perturbation is negative. Why is this not an explanation for the observed acceleration in the expansion of the Universe?
Space news on Phys.org
What exponential time constant? Without dark energy the expansion is not exponential.
The solution to the above Gravitational Stability equation (initial perturbation is e) gives the growth of perturbation
equation
The time constant then is
equation
Also, in words, Einstein had to introduce the Cosmological Constant to adjust for a static Universe. He abandoned it because that would lead to a Gravitational Instability. So why cant we take the CC to be zero and explain the accelerated expansion as the instability?
equation
equation
No, it doesn't. It gives a sinusoid, not an exponential. Check your work.
Also, even that assumes that ##\rho_b## is constant in time. But it isn't. The density of matter decreases with time as the universe expands.
The expansion that Einstein factored out would be a decelerating expansion - as matter and radiation becomes less dense. It requires a vacuum (dark) energy to explain accelerated expansion. That's using the Friedmann equation.
That was why Einstein originally introduced it, but it is not why we currently include it. We currently include it because (a) we have evidence for accelerated expansion of the universe, which requires it, and (b) the term corresponding to it in the Lagrangian should be there by the same reasoning that gives the standard Ricci tensor term.
He was disappointed to discover that his static universe was unstable, yes.
The instability in the static universe is in response to small perturbations about an equilibrium between the density of ordinary matter and the cosmological constant. If you remove the cosmological constant, there is no equilibrium at all and the concept of "instability" as you are using it doesn't even make sense.
In any case, this kind of hand-waving reasoning is not how physics is done. You need to look at the actual math.
PeterDonis said:
That was why Einstein originally introduced it, but it is not why we currently include it. We currently include it because (a) we have evidence for accelerated expansion of the universe, which requires it, and (b) the term corresponding to it in the Lagrangian should be there by the same reasoning that gives the standard Ricci tensor term.He was disappointed to discover that his static universe was unstable, yes.The instability in the static universe is in response to small perturbations about an equilibrium between the density of ordinary matter and the cosmological constant. If you remove the cosmological constant, there is no equilibrium at all and the concept of "instability" as you are using it doesn't even make sense.
My question does not qualify as a hand waving reasoning. Certainly not a dummy here. I quoted the math behind with references therein and asked a hard question.(See above). It takes a bit of time and not answer from the hip. Please pick up Peebles book and go through it. It is amazing in its comprehensiveness even for its age.
  • Skeptical
Likes weirdoguy
You claimed that the solution of the equation ##d^2 l / dt^2 = - k l## is an exponential. It's not. It's a sinusoid.
If ##l(t) = e^{\pm \sqrt{k} t}##, then ##dl / dt = \pm \sqrt{k} l## and ##d^2 l / dt^2 = k l## (notice the lack of the minus sign, since taking two derivatives cancels any minus sign in the exponent).
If ##l(t) = \sin \sqrt{k} t##, then ##dl / dt = \pm \sqrt{k} \cos \sqrt{k} t## and ##d^2 l / dt^2 = - k \sin \sqrt{k} t = - k l##. So that solves the equation (and so would ##\cos \sqrt{k} t##).
Given this obvious error on your part, you are in no position to be claiming that others are shooting from the hip. (And, as I have already pointed out, even all of the above assumes that the ##k## in the equation is actually a constant, but it isn't; it contains ##\rho_b##, which is a function of time.)
I have read it, and I don't recall any claims about "gravitational instability" along the lines you are making. Please be specific about exactly where in Peebles' book the claims you describe are being made.
say_cheese said:
There is a current theory that uses this conjecture to explain the accelerated expansion without dark energy.
I see nothing in the paper that remotely resembles the claim you posted in the OP of this thread. The paper does not even reference Peebles' book.
page 67, Peebles book - gravitational instabilty subsection in book, 1993.
"if the mass density were lower than the critical value, the Universe would expand". The equations aare also from the same subsection.
Also, I feel vindicated. There is actually a theoretical paper proposing this which I have given in the later reply. I found it after I posted the thread.
I don't have my copy handy to check the context, but I suspect you are quoting this out of context. As an isolated statement, it makes no sense. There are expanding models with density lower than critical, equal to critical, and higher than critical.
The equation you posted in the OP is fine in itself, it's just the second Friedmann equation with zero cosmological constant.
The problem is your claim that the solution of this equation is an exponential. It isn't. In fact, once we take into account that ##\rho_b## is a function of time, the solution is a decelerating expansion, which might or might not turn into contraction depending on the density relative to critical. This has been well known basic cosmology for decades.
Very strange that someone would think I would not know the solution to the simple harmonic motion equation. You have not watched the physics behind it, the explanation for this is beautifully described in Peebles book, This has to do with the fact that if the Universe is a balloon, we are inside it. Please go through Peebles book.
  • Sad
Likes weirdoguy
Why is it strange? You are claiming that the solution to this equation is an exponential. That's what you said in post #3 of this thread.
After moderator review, the thread will remain closed.
Related to Gravitational Instability and accelerated explanation of Universe?
What is gravitational instability?
Gravitational instability refers to the process by which small perturbations or irregularities in the density of a gravitational system, such as a galaxy or the universe, grow over time due to the force of gravity. This phenomenon is a key mechanism in the formation of large-scale structures in the universe, including galaxies, clusters of galaxies, and superclusters.
How does gravitational instability contribute to the accelerated expansion of the universe?
Gravitational instability itself does not directly cause the accelerated expansion of the universe. Instead, the accelerated expansion is attributed to dark energy, a mysterious form of energy that permeates space and exerts a repulsive force. However, gravitational instability plays a crucial role in shaping the universe's structure as it expands. The interplay between gravitational attraction (due to matter) and repulsive forces (due to dark energy) dictates the dynamics of cosmic expansion and structure formation.
What evidence supports the accelerated expansion of the universe?
The primary evidence for the accelerated expansion of the universe comes from observations of distant Type Ia supernovae, which appear dimmer than expected, indicating they are farther away than predicted by a uniformly expanding universe. Additional evidence includes measurements of the cosmic microwave background radiation and large-scale structure surveys, which provide independent confirmations of an accelerating universe.
What role does dark energy play in the accelerated expansion of the universe?
Dark energy is hypothesized to be the driving force behind the accelerated expansion of the universe. It is thought to constitute approximately 68% of the total energy density of the universe. Dark energy exerts a negative pressure, leading to a repulsive gravitational effect that causes the expansion rate of the universe to increase over time. The exact nature of dark energy remains one of the biggest mysteries in cosmology.
How do scientists study gravitational instability and the accelerated expansion of the universe?
Scientists study gravitational instability and the accelerated expansion of the universe using a combination of observational and theoretical approaches. Observationally, they use telescopes and detectors to gather data on cosmic microwave background radiation, galaxy distributions, and supernovae. Theoretically, they develop models and simulations based on general relativity and cosmological principles to understand the underlying physics. These models are then tested and refined against observational data to improve our understanding of the universe's behavior.
  • Cosmology
  • Cosmology
