Gravitational lensing and Dark Energy
In summary, gravitational lensing has a primary impact on the CMB by mixing the polarization signal, causing some of the E-mode power to show up in the B-modes. This effect is more prominent at higher values of l, while the ISW effect affects the spectrum at lower values of l. Gravitational lensing can be useful in determining the features of dark energy by measuring the distribution of large scale structure and the rate of expansion over time. However, the direct constraint on dark energy primarily comes from the ISW effect, not from lensing.
astrolollo
24
Hi everyone
I have been told that gravitational lensing affects CMB power spectra (TT, TE, EE) for high values of l (i.e. the least, low peaks on the right, say l>1000). But how? Isn't the effect of the varying gravitational potential along the line of sight the cause of Integrated Sachs-Wolfe effect which affects the spectrum, on the contrary, for low values of l (say, l< 30)? How can we know that the lensing is caused in an accelerating universe scenario? And how can gravitational lensing constrain DE, both in density and in equation of state?
Space news on Phys.org
The primary impact of gravitational lensing is that it "mixes" the polarization signal, so that some of the E-mode power shows up in the B-modes (the primordial B-modes are much, much smaller than the E-modes, so there isn't much contamination in the other direction). Lensing shows up at higher ##\ell## values in the B-modes because the E-modes have more power at higher ##\ell## values (peaking at around ##\ell=1000## or so).
And how is it useful to determine the features of DE?
What do you mean useful?
Many people think dark energy is interesting, and understanding dark energy would give us deeper insight into the most fundamental physical laws. But I don't know what you mean by, "useful."
No, I'm just asking how what you wrote in your answer could be used to determine the presence of dark energy
Ahhh, that makes more sense :)
Dark energy's effect on the CMB is pretty small. For the most part it impacts the low-##\ell## modes through the ISW effect. The effect of lensing on the CMB has very little to do with dark energy.
What you get from gravitational lensing that is useful for dark energy are measurements of the distribution of large scale structure. Measurements of the distribution of large scale structure provide a measurement of how the universe has expanded over time, which is currently the primary method for detecting dark energy (dark energy changes the rate of expansion depending upon its amount and properties).
"The effect of lensing on the CMB has very little to do with dark energy." Are you sure? Planck alone can put some constraints on DE only with lensing..
Not from lensing, I don't think. Or, at least, not directly. The main direct constraint comes from the ISW effect, which isn't a matter of lensing. As I mentioned, lensing can be used to measure large scale structure, and that can be used to measure dark energy through the rate of change of expansion.
Related to Gravitational lensing and Dark Energy
1. What is gravitational lensing?
Gravitational lensing is a phenomenon in which the path of light is bent by the gravitational pull of a massive object, such as a galaxy or cluster of galaxies. This distortion of light can create an optical illusion, making distant objects appear larger or brighter than they actually are.
2. How does gravitational lensing provide evidence for dark energy?
Dark energy is a theoretical form of energy that is thought to be responsible for the accelerating expansion of the universe. Gravitational lensing can help us study the distribution of matter in the universe and how it affects the bending of light. By observing the effects of gravitational lensing, we can gather evidence for the existence of dark energy.
3. What is the difference between strong and weak gravitational lensing?
Strong gravitational lensing occurs when a massive object, such as a galaxy, creates multiple and highly distorted images of a background object. Weak gravitational lensing, on the other hand, produces subtle distortions in the shape of distant galaxies. While strong lensing is easier to observe, weak lensing is more sensitive to the amount and distribution of dark energy in the universe.
4. How does dark energy affect the expansion of the universe?
Dark energy is thought to be the dominant force driving the expansion of the universe. It creates a repulsive force that counteracts the gravitational pull of matter, causing the universe to expand at an accelerating rate. This acceleration was first observed through the study of distant supernovae, providing strong evidence for the existence of dark energy.
5. Can gravitational lensing be used to study the properties of dark energy?
Yes, gravitational lensing is a powerful tool for studying dark energy. By analyzing the distortions in the shapes of galaxies caused by gravitational lensing, scientists can learn about the distribution of dark matter and the expansion rate of the universe. This information can then be used to constrain theories and models of dark energy.
  • Cosmology
  • Cosmology
  • Beyond the Standard Models
  • Cosmology
  • Astronomy and Astrophysics
