Gravitational Lensing: Einstein's Blue Run Mystery
In summary: I don't think all Einstein rings are blue. But far-away galaxies tend to be intrinsically bluer than nearby ones, as galaxies in the early universe were younger and had a lot more star formation. More star formation means a higher abundance of massive stars, and massive stars tend to be both bluer and brighter.
Oscar01
Hi there. Have been doing some informant l independent research on gravitational lensing. It turns out that all einstein runs are blue. Why Is this?
Likes Peter034
Space news on Phys.org
I assume you realize colorization of images is purely a dramatic effect..
Chronos said:
Upon further investigation, I found it is not an effect related to imaging processing nor to the color of galaxies. As usual truth is stranger than fiction as discussed here: http://www.iaeng.org/IJAM/issues_v41/issue_3/IJAM_41_3_02.pdf
Skimming the paper, I don't think it's saying this. Rather, they're proposing a novel modification of General Relativity that makes Einstein rings blue. I'm not confident that this modification is necessary or that there is evidence for it.
I agree. A cursory examination of google images showed several that appeared distinctly yellow. However, I will say that most of them appeared to be blue though.
No doubt. I really think it's down to these being predominantly young galaxies, but I have had a hard time coming up with any good sources for this.
No they are blue unless redshifted. otherwise always blue as is described in this paper that makes an attempt at answering why. http://arrow.dit.ie/engscheleart2/19/
There seems to be no good theory as to why though.
Likes Peter034
That's the same article that's linked above. It doesn't provide actual evidence (e.g. spectra), just a general statement that Einstein rings tend to be blue. It's a purely theoretical paper, which is fine. But it doesn't count as a solid explanation without confirming evidence.
No it isnt. They are seen to be blue in the visual range and given an arbitrary colour if not in visual range.
Is this opinion or can you cite. Because the only citation we have says they are always blue unless redhifted or they're in the visual range.
If they are not blue then the photograph was not taken in the visual range and the colour is arbitrary.
Alot of arbitrary guesses here does anyone have any useful information or citations?
It seems to me odd that there wouldn't be considering the whole theory behind gravitational lensing rest son the absence of chromatic abberation, which doesn't appear to be the case as far as i can see.
Seems to me that you can see it right in the pictures of all gravitationally lensed objects. We don't see different colors being focused at different ranges like a normal chromatic aberration. The only thing odd here is that some gravitationally lensed objects appear to be bluer than they should be.
Infact we don't see different colours at all we only see blue unless redshifted or not in visual range. Unless you can cite a paper that says otherwise. The only one we Have so far agrees with what i Have said above.
You could get this phenomena with normal chromatic dispersion. When shining a white light through a Crystal onto a distant wall the gap between colours would get wider. If you where an ant on one point of that wall it is possible that all you would see Is blue.
Likes Peter034
Maybe. I don't know enough to argue further.
Einstein rings are usually not imaged in visible light ranges, so they obviously must be colorized to render them viewable. According to https://en.wikipedia.org/wiki/Einstein_ring, "... Most rings have been discovered in the radio range." The number of 'optical' Einstein rings is relatively small. For a listing, albeit somewhat dated, see http://science.nasa.gov/science-news/science-at-nasa/1999/ast14may99_1/. Note that the ACS imager aboard the Hubble [see https://www.spacetelescope.org/about/general/instruments/acs/ for technical specifications] used to capture the photos shown is sensitive well beyond the visible range [450-700nm] so it is reasonable to expect at least some of these images are 'enhanced' [colorized] to bring out their more interesting features, much in the same way CMB maps are 'enhanced'. I doubt the sample size of optical data is large enough to permit any reliable conclusions about the apparent 'blueing' of lensed images. On this basis, it could be argued it is little more than an interesting curiousity, although the explanation offered in the IAENG paper looks plausble to me. For further discussion http://hubblesite.org/hubble_discoveries/science_year_in_review/pdf/2006/einstein_rings_natures_gravitational_lenses.pdf may be of interest.
This thread is hopeless. The images you see on the web are all false color. (The so-called science images are not: those are monochromatic with a filter. But there simply are not any true color images taken of these objects.)
The OP denies this in #10. Once you deny the data, it's not science any more.
Now, if the OP were to provide a catalog of lensed object with a quantitative measure of their color, such as B-V, we can discuss whether such a thing is true.
Likes davenn
PS Here's what I tried to write in the other thread:
Oscar01 said:
the fact that nearly all Einstein rings are blue
It is not a fact. Virtually every image you can find on the web is in false color. These galaxies are blue because some human being decided to make them blue. Before determining why something is true, one should first determine if it is true.
Now, if you have a database of lensed galaxies with actual colors (e.g. B-V) we can discuss those. Do you?
Thread closed for moderation.
Edit: this thread will remain closed
Related to Gravitational Lensing: Einstein's Blue Run Mystery
What is gravitational lensing?
Gravitational lensing is a phenomenon in which the gravitational force of a massive object, such as a galaxy or cluster of galaxies, bends and distorts the path of light from a distant object behind it. This creates a visual effect similar to a lens, hence the name "gravitational lensing".
How does gravitational lensing work?
According to Einstein's theory of general relativity, mass and energy can warp the fabric of space-time, causing objects to follow curved paths. When light passes through this warped space, its path is also bent, similar to how a glass lens can bend light. In the case of gravitational lensing, the massive object acts as the lens, bending and magnifying the light from the distant object behind it.
What is "Einstein's Blue Run Mystery"?
"Einstein's Blue Run Mystery" refers to an observation made by astronomers in the 1980s, in which a distant quasar appeared to have a blue streak of light running through it. This was initially unexplained until it was determined that the blue streak was actually a result of gravitational lensing by a massive galaxy located between the quasar and Earth. This observation provided evidence for the existence of dark matter, which is responsible for the bending of light in gravitational lensing.
What can gravitational lensing tell us about the universe?
Gravitational lensing allows us to study the distribution of mass in the universe, including dark matter, which cannot be directly observed. It also allows us to study the properties of distant galaxies and objects, as the lensing effect can magnify and distort their light, providing a clearer view. Additionally, gravitational lensing can help us measure the expansion rate of the universe and test theories of gravity.
How is gravitational lensing useful in astronomy?
Gravitational lensing has numerous practical applications in astronomy. It can be used to detect and study distant objects that would otherwise be too faint to see, such as galaxies and quasars. It can also help astronomers map the distribution of dark matter in the universe and study the formation and evolution of galaxies. Gravitational lensing can also be used to measure the mass of distant objects, providing valuable information for understanding the structure of the universe.
  • Cosmology
  • Cosmology
  • Cosmology
  • Beyond the Standard Models
