Gravitational Perturbation - How does it work?
In summary, Jupiter's gravitational pull causes the Earth's orbit to become more elliptical, but over time the orbit will return to a more circular shape due to systematic interaction effects between the two bodies.
Bjarne
344
It is easy to understand for example how Jupiter pulls (perturbation) the orbit of the Earth more elliptic.
But after a certain period the orbit will again be more circular.
How does that (the opposite) work ?
Astronomy news on Phys.org
What exactly are you asking? How gravitational interactions cause an orbit to become unstable? It's simply that an object gets too close to another object and it's gravitational pull causes a large change in the orbit that cannot be corrected naturally. Was that what you were looking for?
If you have two bodies like Jupiter and the Earth orbiting the same source in near-circular ellipses with different orbital periods, then there will be systematic interaction effects depending roughly on the points in the orbit where they are closest to each other. If the relative orbital periods mean that these points of closest approach tend to occur near particular points in the Earth's orbit for several consecutive orbits, then this creates a systematic effect which tends to lift or drop some parts of the orbit. If the lifting effect occurs at a high point in the orbit, that will make it more elliptical, but if it occurs at a low point it will make it more circular. As the relevant orbits are not very far off circular, the overall effect makes the orbit sometimes more circular than average and sometimes more elliptical.
FAQ: Gravitational Perturbation - How does it work?
1. How does gravitational perturbation affect planetary orbits?
Gravitational perturbation occurs when the gravitational pull of one celestial body causes a disturbance in the orbit of another body. This can cause changes in the shape, size, and orientation of the orbit, leading to variations in the planet's speed and direction.
2. What causes gravitational perturbation?
Gravitational perturbation is caused by the gravitational force between two or more celestial bodies. As they orbit each other, their gravitational pull affects each other's orbits, leading to perturbations.
3. How do scientists study gravitational perturbation?
Scientists use mathematical models and computer simulations to study the effects of gravitational perturbation on planetary orbits. They also observe the movement of celestial bodies and track any changes in their orbits.
4. Can gravitational perturbation lead to collisions between celestial bodies?
Yes, in some cases, gravitational perturbation can lead to collisions between celestial bodies. This is especially true for smaller bodies that are more susceptible to the effects of perturbation.
5. Can gravitational perturbation be used to predict future celestial events?
Yes, scientists can use their understanding of gravitational perturbation to predict future celestial events such as close approaches between planets and the formation of new orbits. This can also help in understanding the formation and evolution of our solar system.
