Gravitational Potential Energy - Kinetic Energy
In summary, using the equations and given values, the kinetic energy of the asteroid just before it hits the ground is calculated to be 2.0673 × 10^14 Joules. This takes into account the change in potential energy as the asteroid falls from 3 Earth radii away to just above the Earth's surface.
Curveball
An asteroid of mass m = 2.6 × 10^6 kg approaches the Earth. When it is exactly 3 Earth radii away from the Earth's centre its speed relative to the Earth's centre is u = 8.7 × 10^3 m s–1.
The asteroid subsequently falls down to the Earth's surface. You may assume that the asteroid remains intact and does not dissipate any energy as it passes through the Earth's atmosphere. You may also ignore the rotation of the Earth and of the asteroid.
Calculate the kinetic energy of the asteroid just before it hits the ground. Give your answer by entering a number, specified to an appropriate number of significant figures, in the empty box below.
Energy Gravitational = -GMm/r
The Earth has mass ME = 5.98 × 10^24 kg and radius 6.38 × 10^6 m.
To find the relevant potential energies you will need to use G = 6.67 × 10^–11 N m^2 kg^–2
[/B]
I believe the best method here is to find the Energy Gravitational when the asteroid is 3 radii away form the centre of Earth and when it is just above the Earth's surface.
The difference is the change in potential energy which is then the kinetic energy gained by the asteroid.
E grav change using -GMm/r = (5.41824 x 10^13 ) - (1.625472727 X 10^14) = 1.083648 x 10^14 Joules
Also the kinetic energy at the start would be 0.5mu^2 = 0.5 (2.6 × 10^6 )(8.7 × 10^3)^2 = 9.84 x 10^13 Joules.
Adding the 2 gives kinetic energy equal to 2.0673 X 10^14 Joules.
Sounds good to me. I checked the calculations and all look correct.
You are using ##(Egrav_1 + Ekin_1)=(Egrav_2 + Ekin_2)##.
Related to Gravitational Potential Energy - Kinetic Energy
1. What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the potential to do work when an object is moved from one position to another due to the force of gravity.
2. How is gravitational potential energy related to kinetic energy?
Gravitational potential energy and kinetic energy are two forms of energy that are related through the law of conservation of energy. As an object falls, its potential energy is converted into kinetic energy, and as it rises, its kinetic energy is converted back into potential energy.
3. What factors affect the amount of gravitational potential energy an object has?
The amount of gravitational potential energy an object has depends on its mass, height, and the strength of the gravitational field it is in. The higher the object is, the greater its potential energy will be. Similarly, the greater the mass of the object, the more potential energy it will have.
4. How is gravitational potential energy calculated?
The formula for calculating gravitational potential energy is PE = mgh, where PE is potential energy, m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object. This formula can be used to find the potential energy at any point in an object's trajectory.
5. What are some real-life examples of gravitational potential energy?
Some examples of objects that possess gravitational potential energy are a roller coaster at the top of a hill, a book on a shelf, and a pendulum at its highest point. In each of these cases, the object has the potential to do work due to its position in a gravitational field.
