Gravitational Potential Energy problem-Physics1-help
In summary: Earth,, is that right or am I missing something:confused:?In summary, an asteroid hits the Moon and ejects a rock with enough speed to travel to a point between the Earth and the moon where the gravitational forces on it from the Earth and the moon are equal and opposite in direction. At this point, the rock has a very small velocity towards Earth, almost zero. The question asks for the speed of the rock when it reaches Earth's atmosphere at an altitude of 700 km above the surface. To solve this, one must assume that the rock starts from rest at this point and use the equation v= √2(-GMearth/7078+GMearth/Rre
moephysics
An asteriod hits the Moon and ejects a large rock from its surface. The rock has enough speed to travel to a point between the Earth and the moon where the gravitational forces on it from the Earth and the moon are equal and opposite in direction. At that point the rock has a very small velocity toward Eart. What is the speed of the rock when it encounters Earth's atmosphere at an altitude of 700 Km above the surface?
Gravitational potential energy: PE= -Gm1m2/r
Conservation of Mechanical Energy: KE(intial)+PE(intial)=KE(final)+PE(final)
well firstly ididnt get what they mean that its moving towrds earth, I mean if the forces between the moon and Earth are equal and opposite in direction shouldn't the velocity of the rock be zero, Ijust need calrification here becuase that was confusing me a bit. And also I tired finding the velocity that it moves with toward Earth but I don't know anything about the distance that it travelled. I just basically need someone to clarify this problem for me that's all and thankyou:).
Okay, I'll try and clarify the problem for you. Imagine that the rock is traveling form the moon towards the earth. Now, when it reaches the point where there is no net force acting on the rock it still moving towards the Earth some non-zero velocity. Recall Newton's First Law, if there are no external forces acting on a body, then the body remains at rest or _________
ohh yea! I see and one more thing when they say enough speed to travel between a point between the Earth and the moon where the gravitational forces are equal and opposite in direction, could they possibly be hinting that the rock would travel initially at the escape speed from the moon or I am I analyzing it the wrong way. that's all and thank you once more:)
I wouldn't say that the rock was launched at the escape velocity. Instead, I would say that at the point between the Earth and the moon where the gravitational forces are equal and opposite in direction, that the rock has a very small velocity - so small in fact that you could consider it to be zero. :wink:
wait, but if its zero how does the rock keep moving towards Earth until it reaches an altitude of 700 km :confused:?
I didn't say it was zero, I said you could consider it to be zero:
If it had a non-zero velocity at this point, then it would simply there forever, never moving. It does have some small velocity at this point to ensure that it doesn't just sit there but moves towards Earth instead. However, this velocity is so small that you can neglect it and assume that the rock starts moving from rest at this point.
Do you follow?
oh ok yea I see where your coming from,, alright thanks a lot your help is appreciated:smile:,, and oh yea one more thing I've been trying to figure out the distance where this rock was undergoing zero net force,, and for some reason I am not getting any where I don't know why. I mean this is how Iam thinking of it I figure out the intial distance between the rock and the Earth then since I am going to assume that it starts from rest I use this equation
v= √2(-GMearth/7078+GMearth/Rre).
Where 7078 is the distance from the Earth center to the point of 700km altitude in km and Rre is the initial distance between the Earth and the rock. Doing that I could figure out the final velocity, but I tired finding the initial distance between rock and Earth but i don't seem to be getting any where.
I think it's best if we start from scratch.
Using Newton's Law of gravitation, can you write down an equation the represents the net force felt by the rock (i.e. the sum of the forces exerted by the moon and earth)?
umm alright yea sure, so it would be something like this
Fnet=GMeMr/Rre^2-GMoMr/Rro^2=0
where Me=mass of earth
Mr=mass of rock
Rre=distance between Earth and rock
Mo=Mass of moon
Rro=distance between moon and rock
Mr=mass of rock
Mo=Mass of moon
Looks good. So we want to figure out where abouts this Fnet is zero. At the moment we have two reference points (the Earth and the moon) and we're measuring the distance from both points of reference re and ro.
To make our life easier, let's pick just one reference point say the centre of the earth. Can you now re-write ro in terms of re and the distance from the centre of the Earth to the centre of the moon deo?
Notice that you can also cancel off the mass of the rock.
ok so Ro=0.2725Re and deo=3.85x10^8 m
so our equation would be somethin like GMe/Deo^2-GMo/0.2725Rer^2=0 ?
Hmmm, not quite. Let's try it like this:
[tex]R_o + R_e = D_{eo}[/tex]
Hence
[tex]R_o = D_{eo} - R_e[/tex]
The using your equation
[tex]\frac{G M_o}{r_o^2} = \frac{G M_e}{r_e^2}[/tex]
We obtain
[tex]\frac{M_o}{\left(D_{eo} - R_e\right)^2} = \frac{M_e}{R_e^2}[/tex]
Do you follow?
alright so you mean it that way ok so far so good...
Good. So to answer your question you need to know where the velocity of this rock can be considered zero. Therefore, you need to determine Re.
Once you have Re the problem is a straight forward application of conservation of energy.
alright thank you very much , i don't know what i would've done without your help:approve::shy:
No problem, it was a pleasure. Feel free to come back if you get stuck later on.
Merry Christmas!
FAQ: Gravitational Potential Energy problem-Physics1-help
What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the potential for an object to do work by moving from a higher position to a lower position in the field.
How is gravitational potential energy calculated?
The formula for gravitational potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object above a reference point. This formula assumes that the gravitational field is uniform and the object is near the surface of the Earth.
What is the difference between gravitational potential energy and gravitational potential?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field, while gravitational potential is the potential energy per unit mass. In other words, gravitational potential energy is the total energy of an object, while gravitational potential is the energy per unit mass at a specific point in the field.
How does gravitational potential energy change as an object moves in a gravitational field?
As an object moves closer to the source of the gravitational field, its potential energy decreases. This is because the object is moving from a higher position to a lower position, and thus has the potential to do work. On the other hand, as an object moves further away from the source, its potential energy increases.
Can gravitational potential energy be converted into other forms of energy?
Yes, gravitational potential energy can be converted into other forms of energy, such as kinetic energy. When an object falls, its potential energy is converted into kinetic energy as it gains speed. This is known as the principle of conservation of energy, which states that energy cannot be created or destroyed, only converted from one form to another.
