Gravitational Potential energy problem
In summary, the problem involves finding the gravitational potential energy of a 400-N child on a swing at different positions. For the first position, where the ropes are horizontal, there is no problem. For the second position, where the ropes make a 30.0° angle with the vertical, the GPE is calculated using Ug = mgy (1-cos30°) instead of just cos30°. This is because the problem asks for the GPE relative to the child's lowest position, which is not at the top of the swing in this case.
aero_zeppelin
86
A 400-N child is in a swing that is attached to ropes 2.00 m long. Find the gravitational potential energy of the child–Earth system relative to the child’s lowest position when (a) the ropes are horizontal, (b) the ropes make a 30.0° angle with the vertical, and (c) the child is at the bottom of the circular arc.
Ug = mgy
For a) there was no problem.
For b) I thought it was as simple as applying Ug = mgy cos 30° = (400 N)(2.0 m) cos 30°
But the book says its Ug = mgy (1-cos 30°)
That's my confusion... why 1 - cos 30° and not cos 30° by itself??
any help? Thanks in advance!
The problem is asking for the GPE relative to the lowest position. For part (b), the figure shows that 2 cos 30 is the vertical distance from the swing to its ropes attachment point. You want the vertical distance from the swing to the low point.
Ok but why substract 1 - cos 30°? :(
thanks for the help!
In the 30 degree position, the vert distance from the swing to the top is 2cos30 m. The vert distance from the low point of the swing to the top is 2. Thus, the distance from the swing in its 30 degree position to the low point is (2) - (2cos30) = 2(1-cos30) m.
lolll it's only factored out right??
Thanks a lot!
Related to Gravitational Potential energy problem
1. What is gravitational potential energy?
Gravitational potential energy is the energy that an object possesses due to its position in a gravitational field. It is the potential for an object to do work as it moves from a higher position to a lower position in the gravitational field.
2. How is gravitational potential energy calculated?
The formula for gravitational potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object in the gravitational field. This formula assumes a constant gravitational field and a point mass.
3. What factors affect gravitational potential energy?
The two main factors that affect gravitational potential energy are the mass of the object and its height in the gravitational field. The greater the mass and/or the higher the object is located, the greater the gravitational potential energy.
4. How is gravitational potential energy related to kinetic energy?
Gravitational potential energy and kinetic energy are two forms of mechanical energy. As an object falls from a higher position to a lower position, its gravitational potential energy decreases while its kinetic energy increases. At the bottom of the fall, all of the potential energy is converted into kinetic energy.
5. Can gravitational potential energy be negative?
Yes, gravitational potential energy can be negative. This occurs when an object is located below the reference point in a gravitational field, such as when an object is in a deep hole or a well. In this case, the potential energy is considered negative because the object would require energy to move from its current position to the reference point.
