Gravitational potential energy question (that my teachers can't explain)
In summary, the question is about which mass, m1 or m2, has greater gravitational potential energy at a given distance from the Earth's center, R. The equation for gravitational potential energy, E_p = -G(mM_E)/r, gives the potential energy as negative, but this is just a result of the chosen reference point. The larger mass, m2, actually has greater potential energy, as seen by measuring the change in potential energy from the Earth's surface to a distance R+h. This is because the attractive force of gravity results in negative work, giving energy out. Ultimately, the sign attached to the potential energy value should not be a factor in determining which mass has greater potential energy.
brian_box
Hi everybody, this is a conceptual question about gravitational potential energy that my textbook and high school teacher seem to give incomplete answers.
The problem involves two masses [tex]m_{1}[/tex] and [tex]m_{2}[/tex], where [tex]m_{2}[/tex] > [tex]m_{1}[/tex], which are both at a radius R from the Earth's center. (The radius R is significantly large that Earth's gravitational field cannot be considered constant).
Question: Which mass has greater gravitational potential energy?
The gravitational potential energy is given by
[tex]
E_{p} = -G \frac{mM_{E}}{r}
[/tex]
where [tex] M_{E} [/tex] is the mass of the Earth.
Since r=R for both masses, the only difference are the masses of the objects. Since [tex]m_{2}[/tex]>[tex]m_{1}[/tex], the equation above would state that the gravitational potential energy (GPE) of [tex]m_{2}[/tex] will be more negative, hence less than the GPE for [tex]m_{1}[/tex].
i.e. [tex]GPE_{m_{1}}[/tex] > [tex]GPE_{m_{2}}[/tex]
However this doesn't seem to make sense to me. Surely a bigger mass above the Earth will have more gravitational energy. The textbook answer tells me that the gravitational potential energy of [tex]m_{2}[/tex] is indeed larger, but it explains it using [tex]E_{p}[/tex] = mgh, where h is the height of the object.
Measured from what point?
There's no absolute significance to potential energy, only to changes in potential energy. It depends on your reference point. The equation you gave takes GPE = 0 at r = ∞. If you wanted to measure which mass has more GPE measured from the Earth's surface, then you'd have to compute the change in GPE from r = Re to r = Re + h. Then you'll see that measured from that point, m2 has greater GPE than m1.
The negative sign on the formula for potential energy is the result of the choice of placement of the origin for the PE measurement. The choice that was selected was to make PE zero when objects are separated by an infinite distance. As a consequence, the attractive force of gravity makes the work required to bring two gravitating bodies towards each other negative - you get energy out, which is why things accelerate when they fall.
As an analogy, suppose Ned and Fred are located at -20m and +7m from the origin along an x-axis. Does Ned have "less distance" from the origin than Fred because his coordinate is negative?
If you want to see that the larger mass has greater "potential" to do work, take the difference between the potentials at two different radii. If the difference is negative, you get energy out of the field, turning into kinetic energy for the mass. If the difference is positive, you had to do work to move the mass to the new position (you either lifted it, or its kinetic energy was "stolen", slowing it down).
So, don't be fooled by the sign attached to the number representing the potential energy; magnitude counts.
Related to Gravitational potential energy question (that my teachers can't explain)
1. What is gravitational potential energy?
Gravitational potential energy is the energy that an object possesses due to its position in a gravitational field. It is the energy that is required to move an object from one position to another against the force of gravity.
2. How is gravitational potential energy calculated?
The formula for calculating gravitational potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object above the ground (or reference point).
3. What affects the amount of gravitational potential energy an object has?
The amount of gravitational potential energy an object has depends on its mass and its height above the ground. The higher the object is, the more potential energy it has, and the more massive the object is, the more potential energy it has.
4. Does gravitational potential energy change with velocity?
No, gravitational potential energy is not affected by an object's velocity. It only depends on the object's mass and height above the ground.
5. Can gravitational potential energy be converted into other forms of energy?
Yes, gravitational potential energy can be converted into other forms of energy, such as kinetic energy, when an object falls or moves downwards due to the force of gravity.
