Gravitational potential energy traveling from earth to mars
In summary, the gravitational potential energy between two planets, such as Earth and Mars, cannot be accurately calculated without taking into account the gravitational potential from other celestial bodies, such as the Sun. This is because the mass and distance of these bodies will affect the potential energy of the "moving" mass. Additionally, the potential energy from other planets, such as Venus, can be neglected in comparison to the main contributors, the Sun, Earth, and Mars.
ago01
46
Imagine a trip from Earth to Mars in terms of gravitational potential energy.
Assuming you have a mass of 70 kg70, what is your change in gravitational potential energy in moving from the surface of the Earth to the surface of Mars in GJ? Don't forget the sun!
Universal gravitation
My attempt:
Let ##M_e## be the mass of the Earth and ##M_m## be the mass of the person. Let ##D_{EM}## be the distance from Earth to Mars and let ##R_e## be the radius of the earth.
Defining these constants (leaving off units for brevity):
Masses in Kilograms (G is not a mass but I'll leave it in this group)
##M_e = 5.97x10^{24}##
##G = 6.67x10^{-11}##
##M_m = 70##
Distances in meters...
##D_{EM} = 3.594x10^8##
##R_e = 6.38x10^6##
Then...
##\Delta{U} = U_{mars} - U_{earth}##
## = -\frac{GM_eM_m}{D_{EM}+R_e} - (-\frac{GM_eM_m}{R_e})#### = -\frac{GM_eM_m}{D_{EM}+R_e} + \frac{GM_eM_m}{R_e}##
## = -\frac{(6.67x10^{-11})(5.97x10^{24})(70)}{3.594x10^{11} + 6.38x10^6} + \frac{(6.67x10^{-11})(5.97x10^{24})(70)}{6.38x10^6} ##
## = 4.37x10^9 J##
## = 4.37 GJ##
But this is incorrect. I understand that when dealing with gravitational potential energy we "move" the mass from infinity to it's "destination" and take the difference to get the potential energy.
It's obvious here I didn't include the sun. I understand that it's supposed to be a hint but I cannot imagine a reason the sun would factor into the potential energy between two other planets. Maybe my professor meant something related to the calculation of the distances? I am unsure. Any help would be greatly appreciated.
Your expression for ##U_{mars}## is quite wrong. You have neither the mass nor the radius of Mars in it.
You should check whether the change in distance from the Sun is significant.
So you don't think that it is important that, in order to go from Earth to Mars, you have climb higher in the Sun's gravity well?
Well when you put it like that...
I suppose my (bad) logic was that this would've been "built in" to the earth-mars equation because the Earth's potential energy (from the equation) would reflect it's distance from the sun, so doing things relative to just the Earth made sense.
I'm going to go review the problem now.
Your mass has a GPE in respect of three larger masses: Earth, Mars and Sun. You need to find how much each is changed by the move.
So thinking about it w.r.t. gravity wells that makes sense. But why wouldn't I need to be concerned with say...venus? Wouldn't Mars also be encountering the gravity wells associated with other large masses?
You don't need to worry about forces or GPEs between the planets and sun. They remain whatever they are, unaffected by your journey.
Likewise, the change in your GPE wrt other planets will be very small. It is much larger in respect of Mars and Earth because you get so close to them, and larger in respect of the Sun because that is so massive.
Technically, you need to consider the potential from all stars in the Universe to get the full potential. However, the change in those potentials is going to be absolutely negligible compared to the main contributor(s), where the main candidates are the Sun, Earth, and Mars. (In actuality, some of those are also negligible, but I will let you figure out which ...)
Likes PhDeezNutz
FAQ: Gravitational potential energy traveling from earth to mars
How is gravitational potential energy related to traveling from Earth to Mars?
Gravitational potential energy is the energy an object has due to its position in a gravitational field. When traveling from Earth to Mars, the object gains gravitational potential energy as it moves away from Earth's surface and towards Mars' surface.
Does the gravitational potential energy change during the journey from Earth to Mars?
Yes, the gravitational potential energy changes as the distance between the object and the two planets changes. As the object gets closer to Mars, the gravitational potential energy decreases, and as it moves away from Earth, the gravitational potential energy increases.
How does the mass of the object affect its gravitational potential energy during the journey to Mars?
The mass of the object does not affect its gravitational potential energy during the journey to Mars. Gravitational potential energy depends on the distance between the object and the two planets, not the mass of the object.
Is there a maximum amount of gravitational potential energy that can be gained during the journey from Earth to Mars?
Yes, there is a maximum amount of gravitational potential energy that can be gained during the journey from Earth to Mars. This maximum is reached when the object is at its farthest distance from both planets and is known as the escape velocity.
How does the gravitational potential energy affect the speed of the object during the journey to Mars?
The gravitational potential energy does not directly affect the speed of the object during the journey to Mars. However, as the object moves away from Earth and towards Mars, the potential energy is converted into kinetic energy, which affects the speed of the object.
