Gravitational potential energy
In summary, the gravitational potential energy of a ball a distance r from the center of the Earth is negative because the potential energy is defined to be zero at infinity, according to the convention for gravitational potential. This is due to the fact that the force of gravity is directed towards the center of the Earth, resulting in a negative potential energy.
bigplanet401
104
Why is the gravitational potential energy of a ball a distance r from the center of the Earth negative?
[tex]
U_\text{grav}(r) = - GMm/r
[/tex][/B]
(To me, this makes sense because gravity is an attractive force and bodies will want to minimize the distance between them if only gravity is acting.)
The force of gravity is given by Newton's universal law, so I'm thinking the potential energy due to this force is the negative of the work done on the ball by gravity over a distance, or
[tex]
\Delta U = -W = - \int_{r_1}^{r_2} \; \mathbf{F} \cdot \mathbf{dr}
[/tex]
since the force and the displacement are in the same direction,
[tex]
\Delta U = -W = + \frac{GMm}{r}\vert^{r_2}_{r_1}
[/tex]
if r1 is at infinity and r2 is equal to r,
[tex]
\Delta U = +\frac{GMm}{r}
[/tex]
What did I do wrong?
First decide whether the force vector should be written as ##\mathbf{F} = + \frac{GMm}{r^2} \hat{\mathbf{r}}## or as ##\mathbf{F} = - \frac{GMm}{r^2} \hat{\mathbf{r}}##.
Then think about whether ##\hat{\mathbf{r}} \cdot \mathbf{dr} = dr## or ##\hat{\mathbf{r}} \cdot \mathbf{dr} =-dr##
Oh...minus sign! That makes since because the force of gravity is directed to the center of the Earth, in the -r^ direction. Thanks!
I would have answered the stated question in a completely different way.
The zero level in a potential field is, in general, arbitrary. For practical purposes, all that matters is the potential differences between points. The choice of where to set the zero is either up to the individual or a matter of convention.
For gravitational potential, the convention is that it is zero at infinity. I leave you to complete the explanation from there.
FAQ: Gravitational potential energy
What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the potential for an object to do work based on its height and mass in relation to a reference point.
How is gravitational potential energy calculated?
The formula for calculating gravitational potential energy is GPE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object relative to the reference point.
What factors affect gravitational potential energy?
The factors that affect gravitational potential energy are the mass of the object, the strength of the gravitational field, and the distance from the reference point. An increase in any of these factors will result in an increase in gravitational potential energy.
What is the relationship between gravitational potential energy and kinetic energy?
Gravitational potential energy and kinetic energy are forms of mechanical energy that can be converted from one to the other. As an object falls, its gravitational potential energy decreases while its kinetic energy increases. At the highest point of an object's trajectory, all of its energy is in the form of gravitational potential energy. At the lowest point, all of its energy is in the form of kinetic energy.
How is gravitational potential energy used in everyday life?
Gravitational potential energy is used in various everyday activities, such as riding a rollercoaster or jumping on a trampoline. It is also used in more practical applications, such as hydroelectric power generation, where the potential energy of water stored in a dam is converted into kinetic energy to turn turbines and create electricity.
