Gravitational potential for various matter configurations
In summary, the conversation discusses calculating the gravitational potential and field for the Earth under three different models: constant density, thin shell empty sphere, and constant linear density. For the constant density model, the gravitational potential outside the Earth is equal to that of a point particle, while the field is given by a simple formula. For the thin shell empty sphere model, the formula for the potential is the same, but the field is different. For the constant linear density model, integration over thin shells is necessary to compute the potential within the Earth.
Afonso Campos
29
Consider the Earth as
1. with a constant density of matter,
2. as a thin shell empty sphere and
3. with a constant linear density of matter ##\rho(r) = \rho_{0}r##.
In all cases, calculate the gravitational potential and the gravitational field everywhere and make a sketch.
1. The gravitational potential outside the Earth is equal to the gravitational potential of a point particle of the mass of the Earth, that is,
$$V = - \frac{GM}{r}.$$
Therefore, the gravitational field is simply
$$g = - \nabla V = - \frac{GM}{r^{2}}.$$
To compute the gravitational potential within the Earth, do I have to slice up the Earth into thin shells of radius ##dr## and integrate over shells which contribute to the potential?
Right.
Related to Gravitational potential for various matter configurations
1. What is gravitational potential?
Gravitational potential is the measure of the amount of potential energy that an object has due to its position in a gravitational field.
2. How is gravitational potential calculated?
The gravitational potential of an object is calculated by dividing its mass by the distance between the object and the source of the gravitational field, and then multiplying by the gravitational constant.
3. How does the gravitational potential change for different matter configurations?
The gravitational potential changes depending on the distribution of mass within an object. Objects with more concentrated mass have a higher gravitational potential than objects with evenly distributed mass.
4. Can gravitational potential be negative?
Yes, gravitational potential can be negative. This occurs when an object has a lower potential energy at a certain point compared to its potential energy at infinity.
5. How does the gravitational potential affect objects in its vicinity?
The gravitational potential affects objects in its vicinity by exerting a force on them, causing them to move towards the center of the potential. The magnitude of the force is directly proportional to the mass of the object and inversely proportional to the distance between the objects.
