Gravitational pull of manmade satellites
In summary, the gravitational pull between famous stars and man-made satellites is significantly different due to factors such as distance and mass. The tidal acceleration created by distant stars is smaller than that of objects closer to Earth, and the tidal forces of planets like Jupiter are higher compared to stars. Astrology, which relies on the influence of celestial bodies, can be tested through empirical evidence and statistical analysis. However, astrologers have a saying that the stars do not compel, leaving room for interpretation and potential flaws in predictions.
Vruchtgebruik
Hi there,
to answer some people believing in astrology, I wanted to know what was the order of magnitude of the difference of the gravitational pull between famous stars & the man-made satellites...
I have no knowledge in math or so I have no idea...
I just thought that I would find it funny if the lost screwdriver from an astronaut orbiting Earth would be 100x more influent than any well know distant star... :p
Or if there is a comparison between pluto pull & the ISS pull...
Anyone able to do the math easily ??
Astronomy news on Phys.org
You can do the math yourself. If an object has mass ##m## and is at a distance ##r## from earth, it's gravitational force will be proportional to ##m/r^2##.
Here are two examples to get you started:
- a moon-sized object twice as far away as the moon would have one-fourth the influence (same ##m## but ##r## is twice as great, ##r^2## is four times as great);
- an object with one one-millionth of the mass of the moon would have to be one thousand times closer than the moon to produce the same pull.
Better yet, do a calculation of the tidal acceleration that each sort of object creates. That's the difference in gravitational acceleration across some distance, like one's size. To lowest order, it's GMa/r^3 for size a. The next-order terms have relative size a/r and thus can be ignored.
It should be easy to do this calculation.
But although one can show that tidal forces of distant objects are teeny teeny teeny tiny, an astrologer can get around that problem by positing some otherwise-unknown force that makes astrology work. This issue can be addressed in these ways:
  1. Independent evidence of such a force
  2. Empirical tests of astrological predictions
For the first one, ask an astrologer about how one could detect the astrological force, for lack of a better name. What effects independent of astrological effects might it have?
In principle, an astrologer could win in the second one, by showing empirical evidence of astrological effects. I say that an astrologer could win there because there are numerous phenomena and effects that were observed long before we developed a good theory for them, and I don't see how astrological effects are fundamentally different.
But astrologers are aware of counterevidence to various astrological predictions, and they have a slogan, "The stars incline, but they do not compel." But there is a big branch of mathematics dedicated to testing for the occurrence of effects that incline without compelling. Statistics. So one ought to do statistical tests of astrological predictions. So far, such tests have failed.
A lot of the visible stars will have more gravitational influence than a satellite in orbit (do the math yourself); however, I think you will find that the gravitational force gradient of a distant star is less than the gradient created by your location on Earth based on altitude and density variations on the Earth's surface, although I haven't done the math on that.
The tidal factor GM/r^3 is equal to ω^2, where ω is the angular velocity of an object in a circular orbit around it with radius r.
A Sunlike star at 1 parsec would produce about 10^(-16) times as much tide as the Sun does. The more distant stars' tides tend to cancel out because of their different directions. Our Galaxy overall produces something like 10^(-17) times as much tide as the Sun does.
Turning to the planets, Jupiter produces the highest tide at about 10^(-5) times the Sun's tides.
The Sun and the Moon make tides on an Earth-surface object that are about 10^(-7) the tide that the Earth produces on it, and for a size of about 1 m, that is about 10^(-7) times the Earth's surface acceleration of gravity.
A 1-ton satellite about 200 km upward makes a tide that is about 10^(-16) what the Earth makes.
Related to Gravitational pull of manmade satellites
1. What is the gravitational pull of manmade satellites?
The gravitational pull of a manmade satellite is the force that the satellite exerts on an object due to its mass and distance from the object. This pull is what keeps the satellite in orbit around the Earth.
2. How is the gravitational pull of manmade satellites different from that of natural satellites?
The gravitational pull of manmade satellites is similar to that of natural satellites, such as the Moon, in that it is caused by the satellite's mass and distance from the Earth. However, manmade satellites are much smaller and have less mass, so their gravitational pull is much weaker compared to natural satellites.
3. Can the gravitational pull of manmade satellites affect Earth's tides?
No, the gravitational pull of manmade satellites is too weak to significantly affect Earth's tides. Tides are mainly caused by the gravitational pull of the Moon and the Sun.
4. How does the gravitational pull of manmade satellites impact their orbit?
The gravitational pull of manmade satellites helps to keep them in orbit around the Earth. However, it can also be affected by other factors such as atmospheric drag and the gravitational pull of other objects in space, which can cause the satellite's orbit to change over time.
5. How is the gravitational pull of manmade satellites measured?
The gravitational pull of a manmade satellite can be measured using mathematical equations that take into account the satellite's mass, distance from the Earth, and the gravitational constant. Scientists can also use specialized instruments on the satellite itself to measure its gravitational pull on other objects in space.
  • Astronomy and Astrophysics
  • Classical Physics
