Gravitational Pull: Sun vs. Earth's on Moon
In summary: This is why the Moon stays in orbit around the Earth instead of the Sun.In summary, the conversation discusses the gravitational pull of the Sun and Earth on the Moon and how it affects its orbit. It is explained that the Sun's pull on the Moon is over twice as great as the Earth's pull, but the Moon remains in Earth's orbit due to the mutual gravity between them. The concept of free fall and the effect of gravity on objects in orbit is also mentioned.
acvessey
Hi. I'm totally new to this forum because I am not seeing what I would refer to as 'logic' on wiki.
I'll make this one easy for someone! Can anyone direct me to a website which might clearly explain the following statement:
"The Sun's gravitational pull on the Moon is over twice as great as the Earth's pull on the Moon": copied from: http://en.wikipedia.org/wiki/Orbit_of_the_Moon
Surely a low density and relatively small (distant) attractor such as our Sun, have a lesser pull than a high density, relatively large (close) object such as our Earth on our Moon? otherwise the Moon would not be in Earth's orbit but rather, falling out of our orbit and toward the sun. Isn't that why the Moon has a huge tidal effect on our oceans but the Sun has bugger-all? Doesn't a rock and feather fall toward an attractor at the same rate in a vacuum!
Cheers.
Tony V
Do the math. The Sun is 333000 times as massive as is the Earth, and is 389 times further from the Moon that is the Earth. 333000/389^2 = 2.2.
Or look up the masses of the sun, moon and earth, and the distances between the Earth and sun (which is the same as the average distance between the moon and the sun) and between the Earth and moon, and calculate the gravitational forces using Newton's law of gravitation.
The moon is traveling at 30km/s ±1km/s around the Sun. The 30km/s is what prevents both the Earth and the Moon from falling onto the Sun. The ±1km/s is due to orbit around the Earth.
The way to look at it is that you can consider the Earth-Moon system going around the Sun from a rotating frame in which Earth remains fixed (ignoring elipticity of the orbit). In that rotating frame, centrifugal force acts on both Earth and Moon and keeps both from falling onto the Sun. In addition to that, the Moon is going around in circles around Earth with gravity providing centripetal force for that motion. There is, of course, also the Coriolis effect, which will alter the Moon's orbital period slightly.
Cheers.
Tony V
Imagine you are in free fall towards the Earth. (We are going to ignore things like friction from air and such) You have a ball that you let go along side you. Both you and the ball fall at the same rate. If you could fall for a long enough period of time you would see that you and the ball start to move towards each other thanks to your mutual gravity.
The same effect occurs with the Earth and Moon. Both are in free fall around the Sun thanks to its gravity, and both are also attracted to each other, forming another orbital system.
Related to Gravitational Pull: Sun vs. Earth's on Moon
1. How does the gravitational pull of the sun compare to that of the Earth on the moon?
The gravitational pull of the sun is much stronger than that of the Earth on the moon. This is because the sun has a much larger mass and therefore exerts a greater gravitational force on objects around it.
2. Why is the moon not pulled towards the sun instead of the Earth?
The moon is in a stable orbit around the Earth due to the balance of gravitational forces between the sun, Earth, and moon. While the sun's gravitational pull on the moon is stronger, the Earth's gravitational force on the moon is strong enough to keep it in orbit around the Earth.
3. Does the sun's gravitational pull affect the tides on Earth?
Yes, the sun's gravitational pull does contribute to the tides on Earth. However, the moon's gravitational pull is much stronger and is the primary factor in causing tides.
4. How does the distance between the sun and Earth affect the gravitational pull?
The gravitational pull between two objects is directly proportional to their masses and inversely proportional to the distance between them. Therefore, as the distance between the sun and Earth increases, the gravitational pull between them decreases.
5. Is the gravitational pull between the sun and Earth constant?
No, the gravitational pull between the sun and Earth is not constant. It varies slightly due to the changing positions of the sun, Earth, and other celestial bodies. However, these variations are very small and have minimal impact on our daily lives.
