71GA
- 208
Some atoms emit X-rays at transition from excited to ground state. Energy of an excited state of the atom ##\scriptsize^{57}_{26}\textrm{Fe}## is ##\scriptsize14.4keV## larger than than the energy of it's ground state. The mass of the atom is ##\scriptsize9.5\times10^{-26}kg##. How much energy that is released during the transition from the excited to the ground state is carried away by the core? What is the ##\scriptsize\Delta \lambda## of the emitted photons? Some crystals are bound so hard that the momentum during transition is carried away by the whole crystal. How many energy is carried away by the crystal of mass ##\scriptsize 1g##? During the experiment which confirmed the existence of the gravitational redshift they used same crystal as a source of monochromatic light while they set same crystal ##\scriptsize 20m## away to absorb the emitted photons. What would be the ##\scriptsize\lambda## of emitted photons from the first crystal and how much would it change because of the change of gravitational energy? Was the width of the emission line wide enough in order to measure the gravitational
redshift?
I have been solving a problem set for the "photon in the gravitational field" and came across this problem. It looks very hard to solve and so far the only equation I needed to solve these types of problems was:
\begin{align}
\lambda_2 = \lambda_1 \left(1-\frac{GM}{c^2r}\right)
\end{align}
I presume that when an atom goes from excited to ground state it would emmitt light of ##\lambda##:
\begin{align}
\Delta W = h\nu = \frac{hc}{\lambda} \longrightarrow \lambda = \frac{h c}{\Delta W} = \frac{6.626\times10^{-34}Js \cdot 2.99\times10^8 \tfrac{m}{s}}{14.4\times10^{3} \cdot 1.602\times10^{-19}J} = 85.9pm
\end{align}
But in our case ##\lambda## will be a bit longer because i know that some of the energy ##\scriptsize\Delta W## will be caried away by the core - through gravitational potential energy i presume (can i use a whole mass of the atom here?). I could calculate the right ##\lambda## if i only knew how much does a radius ##r## change. How do i get radius?
