Gravitational Time Dilation & Orbits of Objects
In summary, the conversation discusses how General Relativity is needed to properly describe orbits in systems with a massive primary object. Gravity is a pseudoforce that comes from the geometry of space-time and in the frame where it is apparent, every action has an equal and opposite reaction. The conversation also mentions the effects of gravitational time dilation on orbits, as well as the concept of spatial distortion. The conversation concludes by mentioning the global positioning system as an example of these concepts in action.
Warfen
For example if there were two objects orbiting each other and one was much heavier than the other, for instance a dwarf star and a neutron star. Would the lighter object have a greater gravitational pull than it's mass would say it should because it's pull was operating longer on the heavier object due to time dilation.
Welcome to PF;
Yes and no.
GR is needed to properly describe the kinds of system where an orbit passes close to a primary ... the more massive the primary, the farther away "close" is.
So the effect is felt in the Solar System - check out the subtleties of Mercury's orbit:
http://www.einstein-online.info/elementary/generalRT/planetAstray
However - objects do not pull on each other in general relativity. Gravity is a pseudoforce that comes from the geometry of space-time. If we want to know about the pseudoforce we need to pick a reference frame (i.e. you see centrifugal and coriolis forces in a rotating frame) ... in the frame where the gravity pseudoforce was apparent, every action has an equal and opposite reaction: so the lighter mass will have exactly the same attraction as the heavy one. So if you've been having trouble finding an answer to your question, this is probably why.
Try modifying it so you ask if some orbits in GR are tighter than the relative masses would indicate for Newton... i.e. Does Newton predict the same orbits for a heavier mass.
Warfen said:
Does Gravitational Time Dilation affect the orbits of things?
There would be no orbits at all without a gradient in gravitational time dilation. The gradient in gravitational time dilation, is directly related to the gravitational free fall acceleration. Additionally to that there is also spatial distortion, which causes orbits to precess.
See the diagrams here:
http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
yes. Time dilation, or time distortion IS a component of gravity. good start.
let me try 'no' as an answer, with caveats. Time dilation and spatial distortion, the curvature of spacetime in your example IS 'gravity', and is a bit different than Newton envisioned, that is, more precise. Hence the effects already described in prior posts: time dilation does affect orbits relative to Newton's predictions.
"longer" or "shorter' depends from where you make your observational measurements, that is, your frame of reference mentioned in post #2. Regarding, 'operating longer', keep in mind local time, say at each of the objects, ticks along steadily at an unchanging rate. Radioactive decay, for example, takes as long at one as the other. Yet if we compare clock times, say, with a distant observer, all three clocks tick at different rates.
PS: Your example reminds me of our global positioning system, a light satellite object orbiting around a 'much heaver' object, earth. There is a LOT going on, and if you want some details:
https://en.wikipedia.org/wiki/Error_analysis_for_the_Global_Positioning_System#Relativity
Thank you all for your answers. I guess I am still thinking in a Newton way but mixing in Relativity concepts which is the crux of my confusion.
FAQ: Gravitational Time Dilation & Orbits of Objects
What is gravitational time dilation?
Gravitational time dilation is a phenomenon in which time appears to pass slower for an object in a strong gravitational field compared to an object in a weaker gravitational field. This is due to the curvature of spacetime caused by the presence of a massive object.
How does gravitational time dilation affect orbits of objects?
Gravitational time dilation affects the orbits of objects by causing them to move at different speeds depending on their distance from a massive object. Objects closer to the massive object will experience stronger gravitational forces and therefore move slower, while objects further away will move faster.
What causes gravitational time dilation?
Gravitational time dilation is caused by the presence of massive objects, such as planets or stars, which create a curvature in spacetime. This curvature affects the flow of time, causing it to pass slower in areas with stronger gravitational fields.
Can gravitational time dilation be observed?
Yes, gravitational time dilation has been observed in experiments and through observations of astronomical phenomena. For example, atomic clocks on Earth have been shown to tick slower than identical clocks in orbit around Earth due to the difference in gravitational force.
Is gravitational time dilation the same as time travel?
No, gravitational time dilation does not allow for time travel. While it can cause time to appear to pass at different rates, it does not allow for movement through time in a linear fashion. Time travel would require the bending of spacetime beyond what is possible with just gravitational forces.
