Gravitational Time Dilation Problem
In summary, according to the equations provided and by assuming that t(city) is 75 years, it can be calculated that the person could have lived approximately 0.01 years longer at sea level compared to living in a city located 3.1km above sea level, based on the concept of observer at infinite distance.
J_M_R
A person lived 75 years in a city located 3.1km above sea level. How much longer could they have lived at sea level? (Times are measured by an observer at infinite distance).
tr/t∞ = {1 - [ (2GM) / (r(c^2)) ]}^(1/2)
Rc (Radius at city) = Rearth + 3.1km
∴ t(sea-level)/t∞ = {1 - [ (2GMe) / (Rearth(c^2)) ]}^(1/2)
and ∴ t(city)/t∞ = {1 - [ (2GMe) / (Rc(c^2)) ]}^(1/2)
t(sea-level) / {1 - [ (2GMe) / (Rearth(c^2)) ]}^(1/2) ≈ t(city) / {1 - [ (2GMe) / (Rc(c^2)) ]}^(1/2)
Having made the the two t∞ equal to each other.
Knowing t(city) = 75 years this gave t(sea-level) as 74.99 years.
Where have I gone wrong as shouldn't t(sea-level) be longer?
What gives you that idea?
I was just using the fact that the question says "How much longer could they have lived at sea level?" so assumed t(sea-level) should therefore be longer?
Ask yourself, which of the two has longer until his 76th birthday according to your calculations.
Ah, so the t(sea-level) has longer until his 76th birthday so the person could have lived 0.01 years longer at sea level according to my calculations?
You got it.
Likes J_M_R
Bandersnatch said:
You got it.
Thanks!
Related to Gravitational Time Dilation Problem
What is gravitational time dilation?
Gravitational time dilation is a phenomenon in which time passes slower in a stronger gravitational field. This means that an observer in a stronger gravitational field will experience time passing slower compared to an observer in a weaker gravitational field.
What causes gravitational time dilation?
Gravitational time dilation is caused by the warping of space-time by massive objects such as planets, stars, and black holes. This warping of space-time causes time to pass slower in stronger gravitational fields.
How does gravitational time dilation affect us?
Gravitational time dilation has been observed and measured in experiments, but its effects are too small to be noticeable in everyday life. However, it is an important factor to consider in fields such as space travel and GPS technology.
What is the formula for calculating gravitational time dilation?
The formula for calculating gravitational time dilation is t0 = tf x √(1 - 2GM/rc2), where t0 is the time measured in a weaker gravitational field, tf is the time measured in a stronger gravitational field, G is the gravitational constant, M is the mass of the object causing the gravitational field, r is the distance from the object, and c is the speed of light.
Can gravitational time dilation be observed in space?
Yes, gravitational time dilation has been observed in space through experiments and observations. For example, clocks on GPS satellites experience time dilation due to their high-speed orbit and weaker gravitational field compared to the Earth's surface.
