Gravitational wave emission from electrons
In summary, Vanadium50 and PeroK have argued that if gravity isn't quantized, atoms wouldn't be stable. They used the bohr radius to calculate the distance between the electron and the nucleus, and found that it would take an electron 10110 seconds to collapse. This is much longer than the current age of the universe, so they say it is proof that gravity is quantized.
HibyPrime
TL;DR Summary
An electron would take ~10^110 seconds to collapse into the nucleus due to gravitational wave emission, assuming gravity is not quantized.
Ok, so I've been on a kick trying to really understand why QM and GR are incompatible. I think I get that GR can't be realistically converted into a quantum field because it creates some infinite series that you can't use the normal tricks you would for other QM fields. Hard block, ok got it.
So then what if gravity just isn't quantized? The best argument I was able to find for why it should be quantized was that an electron orbiting the nucleus would eventually lose energy from gravitational waves and fall into the nucleus. This is the same argument that led to a lot of QM in the first place.
So I managed to do the calculation of how long it would take an electron to collapse in on the nucleus based on nothing but gravitational wave emission. The result I got is ~10110 seconds. If this calculation is right, it just wouldn't have ever happened yet. That number is insane.
Equation for calculating the time to collapse from here: https://en.wikipedia.org/wiki/Gravitational_wave#Binaries
Shortened url for the wolfram alpha link to calculation here: https://bit.ly/2KUmmBa
I used the bohr radius for the distance between nucleus and electron.
First, even classically, your calculation is wrong. The time variation of the quadrupole moment is zero, so no radiation.
Second about "The result I got is ~10110 seconds. If this calculation is right, it just wouldn't have ever happened yet. That number is insane. " Why is the stability of atoms "insane"? Atoms are stable.
Of course atoms are stable, I didn't mean to suggest that they aren't.
When I was trying to learn why it seems that there are a fair number of people that start with the assumption that gravity is quantized, one of the arguments that seemed the most solid was that if it wasn't, atoms wouldn't be stable. I wondered about that for a bit, because gravity is so weak that it might just be that the instability is on such a long timeline, that it might not have ever happened. When I ran the calculation I found a number that is huge, that's what I meant by insane. It could have be 1040 seconds and the result would be the same, atoms are stable. But it's so much bigger than that.
Thank you for pointing out my calculation was wrong, I marked this as beginner for the reason that I really am a beginner in GR. I think I've begun to have decent grasp of SR, only scratched the surface on the maths of GR. I literally don't even know what "time variation of the quadrupole moment" means. I'm going to have to do some more learning.
In the ground state of hydrogen the electron isn't "orbiting" the nucleus in any classical sense. A measurement of the angular momentum of the electron will always return a value of zero. So, however you want to describe this state, it's not going round and round the nucleus.
Moreover, the electron cannot lose energy. It is in the lowest energy state possible.
An electron in some excited states (higher energy levels) has non-zero angular momentum. But, even so, it can only release energy in well-defined quanta that would take it to a specific lower energy level. It can't "spiral in".
I would encourage you to learn SR properly and try to grasp GR if you can. But, if you want to analyse the incompatibility between GR and QM, you are going to need some serious study of QM first. QM is not just classical physics with a bit of quantisation thrown in.
Where have you heard this? Mostly I’m curious.
I'll be honest, the first place I heard this argument was in this video at the 2:30 mark:
I also came across it here while googling to find answers: https://physics.stackexchange.com/q...avitational-atoms-stable-without-quantization
And since I know those aren't really decent sources, I just went looking for papers that have talked about this. I found a (very) old paper trying to apply electromagnetic theories to gravity, and it appears that the author was probably thinking about the same issue (though they don't mention it directly) when writing it: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC522457/pdf/pnas01017-0027.pdf
To be clear, Vanadium50 and PeroK have made it very clear that I've made some assumptions that are just wrong. Just posting so you know where I got the idea :)
Likes PeroK and Nugatory
It depends what you want to learn. Looking at a random paper by Weyl from 1929 may be interesting but it won't lead to a systematic understanding.
The stack exchange post is misguided, I believe. A gravitational atom would satisfy the Schrodinger equation for a suitable gravitational potential.
All very interesting, but perhaps deflects you from a systematic study of the subject of QM.
What level of maths can you handle?
Related to Gravitational wave emission from electrons
1. What are gravitational waves emitted from electrons?
Gravitational waves are ripples in the fabric of spacetime that are produced by the acceleration of massive objects. In the case of electrons, the waves are emitted when they are accelerated or change direction.
2. How are gravitational waves from electrons detected?
Gravitational waves can be detected using highly sensitive instruments called interferometers. These instruments measure the tiny changes in distance caused by passing gravitational waves.
3. Can electrons emit gravitational waves on their own?
No, electrons cannot emit gravitational waves on their own. Gravitational waves are only emitted when there is a change in acceleration or direction, which requires the presence of other massive objects.
4. What is the significance of detecting gravitational waves from electrons?
Detecting gravitational waves from electrons can provide valuable information about the behavior and properties of these fundamental particles. It can also help us better understand the effects of gravity on a microscopic scale.
5. Can gravitational waves from electrons be used for practical applications?
Currently, there are no practical applications for gravitational waves from electrons. However, the detection of these waves can lead to further advancements in our understanding of gravity and potentially open up new possibilities for technology in the future.
  • Beyond the Standard Models
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
