Gravitational waves speed in a medium
In summary, there has been limited research on the speed of gravitational waves through material mediums. This is because most calculations assume negligible mass-energy outside the source region, making the question of speed through mediums outside the scope. However, some suggest that there may be a chance to see an effect in gravitational wave propagation through molecular gas clouds of galactic or intergalactic size. The recent aLIGO result has also put a tight upper limit on dispersion.
Gerinski
323
Electromagnetic waves are known to travel a c in a vacuum, but at lower speeds in a material medium.
What about gravitational waves? They are also predicted to travel at c in a vacuum, but what about them traveling through material mediums? Do they get slowed down? by which factor?
TX
I doubt there has been much work done on that. The calculations I have seen regarding gravitational waves have all assumed that outside the source region there is negligible mass-energy, and accordingly assumes the stress-energy tensor outside the source to be zero. Since a medium has mass, the question of speed through a medium would be outside the scope of such calculations.
See Ingraham, "Gravitational waves in matter," GRG 29 (1997) 117. Ingraham suggests that the best chance for seeing ##v<c## might be in "gravitational wave propagation through molecular gas clouds of galactic or intergalactic size." Although n−1 would be incredibly small, he suggests that you might be able to see an effect accumulated over thousands or millions of light-years.
Note that the recent aLIGO result puts a very tight upper limit on dispersion.
Related to Gravitational waves speed in a medium
1. What are gravitational waves?
Gravitational waves are ripples in the fabric of space-time that are caused by the acceleration of massive objects, such as black holes or neutron stars. They were first predicted by Albert Einstein's theory of general relativity.
2. How do gravitational waves travel?
Gravitational waves travel at the speed of light in a vacuum, which is approximately 299,792,458 meters per second. This is the maximum speed at which any form of energy or information can travel through the universe.
3. How does the speed of gravitational waves differ in a medium?
In a medium, such as a planet's atmosphere or a dense material, the speed of gravitational waves will be slightly slower than in a vacuum. This is because the medium itself will slightly affect the space-time fabric through which the waves are traveling.
4. Can gravitational waves be affected by the medium they travel through?
Yes, the speed of gravitational waves can be affected by the medium they travel through. This is similar to how the speed of light can be slowed down when traveling through a dense material, such as water or glass.
5. Why is the speed of gravitational waves important?
The speed of gravitational waves is important because it helps us understand the fundamental nature of the universe. By studying the speed at which these waves travel, scientists can gain insights into the behavior of massive objects, the structure of space-time, and potentially discover new physics beyond what we currently understand.
