BadSkittles
- 34
Isnt Weight = mass * gravity of earth
so 1 kilogram = 1 lb? Or am i missing something
BadSkittles said:Isnt Weight = mass * gravity of earth
gary32 said:Mass is measured in Kilograms (SI unit)
Weight is measured in Newtons (SI unit)
1kilogram is 2.2lbs,
Lbs (pounds) is another unit of measuring weight
Strictly speaking, the correct US unit is the pound force, not pound. (And being even more strict, the unit of mass is the Avoirdupois pound, but *nobody* uses that qualifier.) The pound is a unit of mass. If you mean force, use "pounds force".PeterO said:And those pounds are a unit of mass also. The American method of calling pounds a force, with slug as a mass confuse this comparison further.gary32 said:Mass is measured in Kilograms (SI unit)
You weigh 102 kg, and a one pound can of beans weighs one pound here, on the Moon, and elsewhere.As for the weight of a person - my own is approx 1000N - we don't like number values to be too large so my weight is generally stated as:
"I weigh (as much as a mass of) 102 kg"
But those words in brackets are never stated, merely implied.
Thus you hear people say "I weigh 102 kg"
I agreeD H said:Pounds aren't metric units. Assuming Earth standard gravity, one kilogram has a weight of 9.80665 Newtons. On the Moon it's about 1/6 that.
AgreeUsing equality (1 kg = 9.80665 Newtons) is not a good idea. A kilogram is not equal to any number of Newtons. The units aren't even equal.
we just call it pounds, both in layman and engineering useStrictly speaking, the correct US unit is the pound force, not pound.
The unit for mass is the slug in USA, but nobody uses that term.(And being even more strict, the unit of mass is the Avoirdupois pound, but *nobody* uses that qualifier.) The pound is a unit of mass. If you mean force, use "pounds force".
Won't happen in the USA for decadesOr just use metric and get rid of the confusion.
This contradicts your opening sttatement. A person with a mass of 102 kg weighs 1000N N on earth. and about1/6 of that on the moonYou weigh 102 kg,
Nah, a pound of beans here on Earth has a mass of 1/32 slug and weighs 1 pound here on earth, per W =mg. On the moon, it weighss about 1/6 of that. In free space, it weighs nothing.A pound of beans weighs 1 pound here, on the moon, or elsewhere.
Who's this "we" you are talking about?D H said:The pound is a unit of mass. If you mean force, use "pounds force".PhanthomJay said:we just call it pounds, both in layman and engineering use The unit for mass is the slug in USA, but nobody uses that term.
Not really. The lay term "weight" has multiple meanings. Sometimes "weight" means mass, other times, force. That's no different from many other words. Words can have multiple meanings. There's nothing wrong with that. In the lay sense, weight oftentimes is a synonym for mass. When someone says "I weigh 102 kg" the meaning is clear: that person is obviously talking about mass.DH said:You weigh 102 kg, and a one pound can of beans weighs one pound here, on the Moon, and elsewhere.PhanthomJay said:This contradicts your opening sttatement. A person with a mass of 102 kg weighs 1000N N on earth. and about1/6 of that on the moon Nah, a pound of beans here on Earth has a mass of 1/32 slug and weighs 1 pound here on earth, per W =mg. On the moon, it weighss about 1/6 of that. In free space, it weighs nothing.
"We" are the engineers of the USA , most of whom have no idea what a Newton is.D H said:Who's this "we" you are talking about?
i guess most of us were never told that. The term mass is used only by the tech folks, never by others. Everything is in weight units.The official unit of mass in the US is the kilogram. This has been the case for over 100 years.
I used it in high school Physics back in 1963As far as the slug is concerned, it didn't even enter into the official lexicon as a derived customary unit of mass until sometime after 1975.
in Physics 101, if you want to use Newtons laws F=ma and W=mg, and you want Your force or weight in pounds, you had best use mass in slugs and acceleration in feet per second per second, if you want to pass.*The* unit of mass in the US is not and never has been the slug.
lawyers and engineers never agree on anything. In fairness, I Asked a few engineers at work today what the unit of mass is. They had no idea, except that you divide weight on Earth by 32 and magically you get the mass unit .NIST Handbook 130 repeatedly says: "NOTE 1: When used in this Law, the term “weight” means “mass.”"
Hah, indeed! I tend to be repetitive.D H said:We've had this fight before, Jay.
Clever!The pound is a unit of money...(snip)...a pound of feathers weighs more than does a pound of silver or gold.
Gravitational weight is the force exerted on an object by a gravitational field. It is directly proportional to an object's mass and the strength of the gravitational field.
Mass is a measure of the amount of matter in an object, while gravitational weight is a measure of the force exerted on an object by a gravitational field. Mass is constant, while gravitational weight can vary depending on the strength of the gravitational field.
Gravitational weight is typically measured in newtons, but it can also be converted to kilograms using the formula W=mg, where W is weight, m is mass in kilograms, and g is the acceleration due to gravity in meters per second squared.
The acceleration due to gravity on Earth is approximately 9.8 meters per second squared. This value varies slightly depending on location and altitude.
Gravitational weight changes on other planets because the strength of the gravitational field is different. For example, an object that weighs 100 newtons on Earth would only weigh 37.8 newtons on Mars due to the weaker gravitational field.
