Gravity and massless particles
In summary: This means that not only massive particles, but also massless particles like photons, can contribute to the curvature of spacetime and therefore interact with other masses through gravity. This explains the phenomenon of gravitational lensing, where the path of light is bent by the curvature of spacetime caused by massive objects. In summary, gravity is a local curvature of spacetime caused by the energy and momentum of objects, including both massive and massless particles.
dschwie
Just finished reading Sean Carroll's "The Higgs Boson and Beyond". I would be grateful if someone could explain how gravity, which I understand to be a function of mass, can interact with massless particles as evidenced by the phenomenon of gravitational lensing. I understand that gravity is a local curvature of spacetime and photons move through spacetime so that makes sense. Is the explanation as simple as that?
Thanks and regards.
Yes but would massless particles like photons moving through space make gravity.
So in effect could massless particles moving through space time attract each other.
Likes dschwie
Likes dschwie
Yes. In general relativity, the "source" of gravity is the stress-energy tensor, whose components contain the energy and momentum of an object. Mass is only one form of energy.
Likes dschwie
Energy mass equivalence, gravity can also therefore be described as a function of energy.
Likes dschwie
FAQ: Gravity and massless particles
What is gravity and how is it related to massless particles?
Gravity is a fundamental force of nature that describes the attraction between objects with mass. Massless particles, such as photons, do not have mass but they are still affected by gravity due to their energy and momentum.
Can massless particles be affected by gravity?
Yes, even though massless particles do not have mass, they have energy and momentum which means they can still be influenced by gravitational forces.
How does the theory of relativity explain the behavior of massless particles in relation to gravity?
The theory of relativity, specifically Einstein's general theory of relativity, explains that gravity is not a force between masses, but rather the curvature of spacetime caused by the presence of mass and energy. This theory also predicts the behavior of massless particles in gravitational fields.
Do massless particles experience time dilation due to gravity?
Yes, according to the theory of relativity, massless particles are also affected by time dilation in gravitational fields. This means that time will appear to pass slower for a massless particle in a strong gravitational field compared to a massless particle in a weaker gravitational field.
Can massless particles escape the gravitational pull of a black hole?
No, according to the theory of relativity, the escape velocity of a black hole is greater than the speed of light. Since massless particles travel at the speed of light, they cannot escape the gravitational pull of a black hole.
