Gravity and Rotation: Exploring the Milky Way's Mass Increase
In summary: To significantly decrease gravity, we would need to increase the rotation of Earth to extreme speeds, which is not feasible. This has been tested on a small scale with objects like gyroscopes, but it is not practical on a larger scale. In summary, the increased mass of the Milky Way due to faster rotation does not have a significant effect on a single planetary body like Earth, but the faster rotation can indirectly affect the gravity experienced by a single planetary body due to frame-dragging. Decreasing gravity on Earth by spinning it quickly is theoretically possible, but not practical on a large scale.
ndvcxk
Science news recently reported milky way rotates faster than thought - hence more mass. How does this work out for a single planetary body: If rotation is accelerated, my thought was: less gravity, bec. higher centrifugal force. Now, I'm thinking - more mass due to rotation hence more gravity. For discussion, let us assume an earth-size body made of identical solid material which cannot "fly-off", no geostrata with different properties.
On a sidenote, if the rotation->mass increase is correct, we should be able to decrease gravity here on Earth below an elevated, smooth, large globe, as we let it spin fast. Has this been tried ?
Thx for comments !
Mike
Astronomy news on Phys.org
The increased mass of the Milky Way due to faster rotation does not directly have an effect on a single planetary body like Earth. The increase in the mass of the Milky Way would cause the gravitational pull on Earth from the Galaxy to be slightly stronger, but the difference would be negligible. However, the faster rotation of the Milky Way can indirectly affect the gravity experienced by a single planetary body. For example, if two large galaxies merge and the resulting galaxy rotates faster than before, the increased rotation can cause space-time to warp, which can affect the gravitational field around a single planetary body. This phenomenon is known as frame-dragging and has been observed around Earth. In terms of decreasing gravity here on Earth, it is theoretically possible to decrease the gravity experienced by an object by spinning it very quickly, as you suggested. This is known as the centrifugal force and is due to the object's inertia. However, this would only be effective at a very small scale, as the effects of the centrifugal force are negligible compared to the gravitational pull of Earth.
Related to Gravity and Rotation: Exploring the Milky Way's Mass Increase
1. What is the relationship between gravity and rotation in the Milky Way?
The gravity of the Milky Way plays a crucial role in its rotation. The mass of the galaxy creates a gravitational force that keeps the stars and other celestial bodies in orbit, causing them to rotate around the galactic center.
2. How does mass increase affect the rotation of the Milky Way?
The increase in mass of the Milky Way can affect the rotation of the galaxy in several ways. As the mass increases, the gravitational force also increases, causing the rotation to speed up. Additionally, the distribution of mass can also impact the rotation, as more mass concentrated towards the center of the galaxy can cause the outer regions to rotate faster.
3. What is the significance of studying the Milky Way's mass increase?
Studying the mass increase of the Milky Way is essential for understanding the evolution and structure of our galaxy. It can also provide insight into the formation and behavior of other galaxies in the universe.
4. How do scientists measure the mass increase of the Milky Way?
There are several methods that scientists use to measure the mass increase of the Milky Way. These include observing the rotation curve of the galaxy, studying the motion of stars and other celestial bodies, and analyzing the effects of gravitational lensing.
5. Can the mass increase of the Milky Way change over time?
Yes, the mass of the Milky Way can change over time due to various factors such as interactions with other galaxies, accretion of gas and dust, and the formation of new stars. Studying these changes can provide valuable information about the evolution of our galaxy.
