Gravity around small black holes
In summary: This effect is strongest within a distance of about 100 kilometers from the black hole, and the lowest stable orbit depends on the black hole's spin. For a non-rotating black hole, the lowest stable orbit is about 9 kilometers, with the lowest circular orbit being at about 4.5 kilometers. However, the concept of "radius" is not straightforward near a black hole. In summary, a black hole's mass and size can lead to extreme distortions in gravity, affecting orbits of objects within a limited distance.
Paul Katan
If a black hole had a mass similar to the Sun (I know black holes tend to be at least three times larger but let's assume an unusual series of events) how far would the are of extremely distorted bent gravity around it be could it cause closely orbiting bodies to be pulled or pushed out of orbit around the black hole?
Astronomy news on Phys.org
A black hole has stable orbits around it in the same way all other objects have them. Even better: sun is a bit oblate due to its rotation, which has a notable influence on the perihelion precession of Mercury for example. A black hole is much smaller, so this effect gets much smaller as well.
Relativistic effects become strong very close to the black hole - for 1 solar mass, for distances below ~100 km. There are no orbits around the sun at that distance because sun is much larger, obviously. The lowest stable orbit depends on the spin of the black hole. If it is not rotating, the lowest stable orbit has a radius of about 9 kilometers. The lowest circular orbit is at about 4.5 kilometers (light can orbit here), and everything below that either falls into the black hole or escapes directly.
Note that "radius" is not a trivial concept close to a black hole.
Thanks
Related to Gravity around small black holes
1. How does gravity behave around a small black hole?
Gravity around a small black hole behaves in the same way as gravity around any other object with mass. The strength of the gravitational force depends on the mass and distance from the object. However, the gravitational force around a small black hole can be significantly stronger due to its high density.
2. How is gravity affected by the size of a black hole?
The strength of the gravitational force around a black hole is directly proportional to its mass. This means that as the size of a black hole increases, so does its gravitational pull. However, the size of a black hole does not directly affect the behavior of gravity around it.
3. Can objects orbit around a small black hole?
Yes, objects can orbit around a small black hole just like they can orbit around any other object with mass. The only difference is that the gravitational force around a small black hole is much stronger, which means the object would need to be moving at a much higher speed to maintain its orbit.
4. How does gravity around a small black hole affect time?
According to the theory of general relativity, time is affected by gravity. The closer an object is to a small black hole, the slower time will appear to pass for that object. This is known as time dilation and has been observed in the vicinity of large black holes.
5. Is it possible to escape the gravitational pull of a small black hole?
It is theoretically possible to escape the gravitational pull of a small black hole, but it would require an extremely high amount of energy. The closer an object is to the black hole, the stronger the gravitational pull and the more energy it would need to escape. In most cases, it is not possible for an object to escape the gravitational pull of a small black hole.
  • Astronomy and Astrophysics
