Gravity as a non renormalizable theory
In summary: QFT in...?In summary, the papers you want are: One-loop divergencies in the theory of gravitation. G. 't HOOFT (*) and M. VELTMAN and The ultraviolet behavior of Einstein gravity. Goroff and Sagnotti.
shereen1
51
Dear All
I have a project on the topic: " Explaining Why gravity is a non renormalizable theory?". I have downloaded many papers but i need your advice about which paper you think would most benefit me.
Thank you
The papers you want are:
and
The heuristic proof of the power counting argument for the nonrenormalizability of the Einstein Hilbert action can be found in many textbooks. For instance Zee, quantum field theory in a nutshell.
Likes dextercioby and shereen1
Likes Greg Bernhardt, Ravi Mohan and Demystifier
A. Neumaier said:
canonical quantum gravity is perfectly valid as an effective field theory:
Effective to what energy scales?
Also, does that effective means without other forces? Or just gravity? What is the importance of this:
"this constitutes hard evidence that the asymptotic safety program indeed can give rise to a consistent quantum theory of gravity within the framework of quantum field theory along the lines envisioned by Weinberg"
http://arxiv.org/pdf/1601.01800v1.pdf
How does this new work relate to the doubts posed by Distler?
Such that the leading effects become noticeable. below that, quantum gravity is not needed; sufficiently above that, one would have to fit a few further constants to the experiments, the number of constants needed slowly increases with the energy.
In the paper just gravity. But nothing fundamental is in the way of treating in the same way gravity plus standard model, except that one probably cannot do the computations anymore.
Asymptotic safety is a possible way to raise canonical gravity from an effective field theory to a fundamental one. On first sight, the paper looks very promising.
I don't know the doubts posed by Distler. Note that I am not an expert in quantum gravity, though I know enough QFT to understand the paper I cited.
Likes MTd2
It's that you posted the links in your website to his criticism, so I thought you could help me understand.
Ah, I had written it so long ago that I didn't remember all the details. Here is Distler's criticism:
''The trouble is that all hell breaks loose for ε∼1. Then all of these infinite number of coupling become equally important, and we lose control, both computationally and conceptually.''
He writes ##\varepsilon## for the square of ##E/M_p##, where ##E## is the energy and ##M_p## is the Planck mass. Yes, I agree with his criticism, but none of us will live till the time when this regime can be experimentally probed. Thus I am happy to leave the resolution of this difficulty to the future.
But there are others who are more impatient than I am. Since the trouble would be cured by giving a nonperturbative definition of gravity, asymptotic safety will do it, if it can be demonstrated nonperturbatively. The paper you cited shows that asymptotic safety is, or seems to be [I haven't checked the details] present on the perturbative level. Thus the prospects are good that it is also valid nonperturbatively.
Likes MTd2
Perturbatively the prospects have been good for a long time, eg. http://arxiv.org/abs/0805.2909 - but how can one go from perturbative to non-perturbative - I think that's where asymptotic safety is stuck.
Just like any other approach. This doesn't count against it.
Nonperturbatively, even standard QED or QCD are stuck.
But aren't those proved in principle, by counting the divergence of the terms?
This only proves the existence of the renormalized perturbative series.
But this doesn't define the theory since it gives only an asymptotic series for the physical quantities, which is not good enough since infinitely many functions have the same asymptotic series.
That's why people talk about nonperturbative construction. One can treat quantum field theories on the lattice, which counts as nonperturbative, but the lattice approach has other difficulties. In particular, it breaks all continuous symmetries. To recover these, one has to take a continuum limit, and there all problems resurface.
No interactive relativistic QFT in 1+3 dimensions is under full nonperturbative control - which would mean: has a sound mathematical basis. One can do it either with full control of all limits in lower dimension, or with uncontrolled approximations in 4D. To construct an interactive QFT in 4 dimensions in a fully sound way is one of the big unsolved problems. The simplest case to be constructed first is considered by many to be Yang-Mills theory (i.e., QCD without quarks, glueballs only). But even this is already deemed very hard - it is one of the 7 Clay Millennium problems.
Likes MTd2
BTW, has anyone tried to arrange diagrames in predictable, infinite patters, like fractals of perturbative expansion until a boundary which is continuous?
Yes. This is called resumming the series. There are various ways of doing it. The most standard one is the use of the Schwinger-Dyson equation to get useful approximations to the renormalized propagators. The resulting propagators have poles at (approximations to) the physical masses, while the perturbation series itself doesn't show them. It is useful and necessary in practice.
But it is all black art without any real support in the math. It is known rigorously that for any arbitrary asymptotic series there exist infinitely many different functions that have this series as their Taylor expansion. Hence no amount of rearranging the series can supply the missing information needed to identify the right nonperturbative function.
There is another important resummation technique called Borel summation. This has a mathematical rigorous setting, and reconstructs under certain assumptions on the growth of the coefficients a unique function with the given asymptotic series. Thehe applicability of the math depends on assumptions on the analytic behavior of the limit function, which sometimes can be proved to work in lower dimension. But they haven't been verified in 4D QFT, and there are obstructions (renormalons) that are believed to invalidate this approach to 4D QFT.
Likes jordi and MTd2
But it seems some black art yields more confidence than others. So, how to increase the confidence?
If the results agree well with experiments, the black art is considered fully justified. This even justifies (with a little less force) the same black art applied to similar problems. (The amount of similarity is in the eyes of the beholder). With even less force, black art is considered justified if you can convince the referees of your research paper that what you do is plausible.
Because of this, theoretical physics is quite different from mathematics. This is why much of physics can be non-rigorous without undue harm.
I would like a more technical answer...
I don't think there is any. As I indicated, it is a social process by which theoretical physics is justified. Much of it leads to predictions that are in good agreement with experiment. Everything that uses the thus established techniques is considered good scientific practice. Even if it is not (or not yet) backed up by experiment - as long as there are no contradictory experimental findings.
Likes MTd2
A. Neumaier said:
In order not to raise false beliefs, you should also explain in your project why, in spite of its nonrenormalizability, canonical quantum gravity is perfectly valid as an effective field theory:
C.P. Burgess, Quantum Gravity in Everyday Life: General Relativity as an Effective Field Theory, Living Reviews in Relativity 7 (2004), 5
I just found the following recent survey of canonical quantum gravity and its confrontation with exciting experimental data:
R.P. Woodard, Perturbative Quantum Gravity Comes of Age, Int. J. Modern Physics D 23 (2014), 1430020. http://arxiv.org/abs/1407.4748.
Woodard writes in the introduction:
All of the problems that had to be solved for flat space scattering theory in the mid 20th century are being re-examined, in particular, defining observables which are infrared finite, renormalizable (at least in the sense of low energy effective field theory) and in rough agreement with the way things are measured. [...] The transformation was forced upon us by the overwhelming data in support of inflationary cosmology.
This makes me wonder just how fundamental and valid QFT as a framework really is, in general terms. I have only just begun studying QFT in recent weeks, so I'm still largely ignorant of the finer points and issues, but even in the most simplistic of textbook cases ( e.g. quantisation of Klein-Gordon fields ) there already seem to be fundamental issues and quite a bit of handwaving going on ("let's just subtract that infinity to fix that other infinity..."). I do not for a minute doubt or dispute the successes of the Standard Model in describing real-world physics, but the foundation this all stands on appears to me to be shaky and ad-hoc at best. Something just does not feel right about QFT to me; I can't put my finger on it, it's just a matter of intuition. I will keep learning, but there remains an itch that feels as if it badly needs to be scratched :wideeyed: Am I the only one who feels that way ?
Likes Qcontinuum and haushofer
So, in just a few weeks of study you have concluded that everyone else is doing it wrong?
The mathematical foundations of interacting relativistic quantum field theory in 4 dimensions are nonexistent but there is lots of evidence that there is a consistent foundation independent of all the handwaving: All approximate, ad hoc, and/or handwaving ways of doing things lead with proper care to exactly the same results where they are comparable, and no inconsistency has ever been found. (Quantum gravity being not renormalizable is not a counterexample.) That the foundations are one of the Clay Millennium Problems is indication that something very important is missing and worth the prize. Until someone solved it, we must be content with the established mess, no matter how badly one feels about it. You are definitely not an exception in this respect. I still have this feeling after nearly 30 years of studying quantum field theory.
Likes Markus Hanke
I just came across these lectures notes on arxiv. From its title, I get the impression that it may help some people in this thread. But I haven't read it yet.
Likes Demystifier and Markus Hanke
Absolutely not, and to be honest I am quite surprised that this is how you interpreted my post. QFT is manifestly a very successful theory, there can be no doubt or argument over that. It is just that there are elements to it that feel ad-hoc and "messy" to me; it's a matter of intuition, I can't help it. And judging by A. Neumeier's comment as well as the link that ShayanJ has provided, it seems I am not the only person feeling that way.
Perhaps things will become clearer and more logical to me as I progress onwards and keep learning - time will tell.
Allow me to quote one sentence in particular from the link in post #23 which captures perfectly how I feel at the moment ( bottom page 1 ) :
"Often, one is left with the impression that there is some blind faith required on the side of the physicists or at least that some black magic is helping to obtain numerical values that fit so impressively what is measured in experiments from very doubtful expressions."
I could not have put it more succinctly.
you have infinities in classical physics aswell. What is the potential energy for a system of two electrons positioned at the same point in space?
Could you give an observed example of such a system? It is an example beyond the scope of any kind of physics.
why is it an example beyond any scope of physics?
If quantum mechanics is correct, then there is a nonzero probability that two electrons can occupy the same position in space.
In order to solve this - you introduce an electron-radius, two electrons can not occupy the same point in space due to their spatial separation.
In quantum field theory, you solve this problem differently. There you postulate that only the energy-difference is observable - you can not observe the "bare" energy. By considering energy differences only, the infinities are removed (renormalized)
Not true in GR.
Naive non-renormalisability is just one of many problems that arise if you try to quantise gravity. There are clashes between unitarity and locality at a deeper level. They manfest themselves for example in black holes. Naive approaches such as UV fixed points do not shed any light on these questions. This is naive QFT like thinking. You need to think broader than what you have learned from QFT textbooks.
What becomes more and more clear is that GR is an effective, emergent theory that should not be quantized as such. It does not make sense to stare at the GR lagrangian und agonise about how to quantize it and make sense of loops, etc. It should be the other way around: nature is intrinsic quantum, and sometimes, in some limits, there is a reasonably good classical approximation to it. It seems that eg in black holes, macroscopic (non-local) quantum effects play a crucial role, holography as well, and there is no obvious way to get to there from starting with the Einstein lagrangian, modifying it, guessing fixed points, discretizing it, etc.
Likes jordi
Related to Gravity as a non renormalizable theory
1. What is a non-renormalizable theory?
A non-renormalizable theory is a theory that cannot be fully described or predicted using the methods of renormalization, which is a mathematical technique used to correct for infinities that arise in quantum field theories. In non-renormalizable theories, these infinities cannot be eliminated, making the theory incomplete or inconsistent.
2. Why is gravity considered a non-renormalizable theory?
Gravity is considered a non-renormalizable theory because it does not fit into the framework of quantum field theories, which are the basis for most of our understanding of fundamental interactions in nature. The equations of general relativity, which describe gravity, cannot be renormalized, leading to infinities that cannot be eliminated.
3. What are the implications of gravity being a non-renormalizable theory?
The implications of gravity being a non-renormalizable theory are that it cannot be fully integrated into our current understanding of fundamental interactions. This means that it is not compatible with other theories, such as quantum mechanics, and cannot be used to make accurate predictions at the quantum level. It also suggests that there may be a deeper, more fundamental theory that can fully describe gravity and its interactions.
4. Can gravity be renormalized?
No, gravity cannot be renormalized using current methods. However, there have been attempts to develop new mathematical techniques and theories, such as string theory, that may be able to incorporate gravity into the framework of quantum field theories and make it renormalizable.
5. How does the non-renormalizability of gravity impact our understanding of the universe?
The non-renormalizability of gravity has a significant impact on our understanding of the universe, as it limits our ability to fully describe and predict the behavior of gravity at the quantum level. This means that we are not able to fully understand the fundamental interactions of the universe, and it may be necessary to develop new theories and methods in order to do so.
