Gravity as geometry vs as a force
In summary, there are two alternative concepts of gravity: as the warping of space by matter and as the exchange of gravitons. The latter is a theoretical concept that may be verified experimentally in the future. These alternative concepts can be reconciled by understanding gravity as a classical field or a quantum interaction. The exchange of gravitons can produce a force of attraction in a similar way to the exchange of photons in electromagnetism. However, there are some potential pitfalls related to topology when considering an unobservable flat underlying structure. This approach may not fully explain all aspects of general relativity, such as black holes. It is unclear how these concepts can be experimentally tested.
Cobalt101
27
I'd appreciate some explanation on how does one understand/reconcile the seemingly alternative concepts of gravity as (i) due to the warping of space by matter vs (ii) the exchange of gravitons. Is the latter a construction of how gravity can be considered within a quantum mechanics framework ? And how would exchange of gravitons produce a force of attraction anyway ?
First of all, gravitons have not been observed and nobody expects to observe them any time soon. They are just a theoretical concept that many physicists like because of the obvious analogy with other interactions when modeled using quantum field theory. So the answers I will give below are only valid on the assumption that this theoretical concept will actually turn out to be verified experimentally at some point.
The same way we reconcile the classical and quantum views of other interactions. For example, electromagnetism can be thought of as a classical field, or as a quantum interaction mediated by the exchange of photons. Which model we use depends on the specific scenario; the classical model works well for many scenarios but has limitations; the quantum model is more fundamental but also harder to use.
The same way an exchange of photons between particles of opposite charge produces an attraction. A good brief discussion by John Baez is here:
http://math.ucr.edu/home/baez/physics/Quantum/virtual_particles.html
If you want to ask further questions on this particular topic, you should start a new thread in the Quantum Physics forum.
It's probably too technical, but http://arxiv.org/abs/astro-ph/0006423 does discuss one possible non-geometrical approach to gravity.
A pedagogical description of a simple ungeometrical approach to General Relativity is given, which follows the pattern of well understood field theories, such as electrodynamics. This leads quickly to most of the important weak field predictions, as well as to the radiation damping of binary pulsars. Moreover, certain consistency arguments imply that the theory has to be generally invariant, and therefore one is bound to end up with Einstein's field equations. Although this field theoretic approach, which has been advocated repeatedly by a number of authors, starts with a spin-2 theory on Minkowski spacetime, it turns out in the end that the flat metric is actually unobservable, and that the physical metric is curved and dynamical.
If you take the theory really seriously as a way to teach GR, though , there may be some pitfalls related to topology - which, however, the author doesn't discuss. Basically, if one envision an unobservable flat underlying structure to space-time, one can't imagine multiply-connected topologies (at least, I don't see any way to do it), but with the geometric view, one can imagine multiply connected topologies.
The oversimplified version: If one follow Straumann's approach, one might understand a lot of the predictions of GR, but one probably won't understand black holes in the same manner that traditional GR does.
It's unclear to me how (or even if) this could be experimentally addressed, though.
FAQ: Gravity as geometry vs as a force
What is the difference between gravity as geometry and gravity as a force?
Gravity as geometry is the concept that gravity is not a force, but rather the curvature of spacetime caused by the presence of mass or energy. This is described by Einstein's theory of general relativity. On the other hand, gravity as a force is the traditional understanding of gravity as a force of attraction between two massive objects.
How does gravity as geometry explain the motion of objects in space?
According to general relativity, objects with mass or energy cause a curvature in spacetime, which is perceived as gravity. This curvature determines the path of an object in space, allowing for the prediction of its motion.
Is gravity as geometry a proven theory?
Yes, gravity as geometry has been extensively tested and is considered a well-established theory in physics. It has been successfully used to predict and explain many gravitational phenomena, including the motion of planets and the bending of light by massive objects.
What are some evidence for gravity as a force?
One of the main pieces of evidence for gravity as a force is the observation of objects attracting each other. This is most commonly seen in the interaction between the Earth and other celestial bodies, such as the Moon and other planets. Additionally, the laws of motion and gravity developed by Sir Isaac Newton provide a mathematical framework for understanding gravity as a force.
Can gravity as geometry and gravity as a force coexist?
Yes, while they are fundamentally different concepts, gravity as geometry and gravity as a force can coexist and complement each other. In fact, Einstein's theory of general relativity incorporates Newton's laws of motion and gravity as a special case, making it a more comprehensive theory.
